  • SN95 4.6L Mustang Tech
Engine building know it alls come in!
  • Thread starter Thread starter 1fast03pony
  • Start date Start date Feb 12, 2006
1fast03pony
749
New york
Feb 12, 2006
  • Feb 12, 2006
Ok heres the deal
Theres been some toying with ideas of getting a second car to mod the **** out of and keep my stang as is, but its not flyin
Ive made some decisions as to mods, and i need a little advice
My hp goal is anywhere from 450-500 whp and im being broad because i dont want to stress about that right now
I want a built motor that can handle that power. That being said, I've been lurking over at the MPH forums and checkin out the blower setups everyones got. I saw a particular setup that seemed nice, its "jdstang03"s setup and It includes:
sean hyland stroker "mod" 302ci
sean hyland stage 1 heads
foxlake p-51 intake
55lb injectors
vortech sq
2.8 blower pulley with 8-rib kit
sct maf meter
anderson powerpipe
bbk 75 mm tb
bbk long tube headers
596hp/519tq
Im pricing these things out, and holy **** are they expensive.
Im just concerned here about the motor build/forge. I know what supercharger id like to get and thats decided. Im just not sure about the stroker block and heads.
Question: go with a fully built block and heads to go with it
or just get a forged rotating assembly and call it a day...
I feel like this is a "do it right the first time" issue and if i 'settle' for the internals id be severly limiting myself safety and powerwise.
The difference between the SHM stuff and the rotating assembly option is about 4 grand.
What to do? any ideas?
R
RedGTvert
3,129
Wellington, FL
Feb 12, 2006
  • Feb 12, 2006
Don't mess with SHM. Call Tim at MPH for some real guidance, he won't steer you wrong. He can do the full buildup for you and you will spend less than anything that SHM will do.
Either way 500+rwhp will not be exactly cheap.
TweekedGT
1,274
Alberta
Feb 13, 2006
  • Feb 13, 2006
1fast03pony said:
Ok heres the deal
foxlake p-51 intake
55lb injectors
vortech sq
sct maf meter
anderson powerpipe
bbk 75 mm tb
596hp/519tq
Why do you say you will be limiting yourself with just the rotating assembly? It will be just as good yet cheaper if you do it right.
1fast03pony
749
New york
Feb 13, 2006
  • Feb 13, 2006
I was thinking this as well. Im ready to spend money to get to my goal, but like anyone else in here I wont overpay for it.
I just feel that the heads would compliment the setup alot better with more power. Im new to engine building so im tryin to do as much research as possible
98blackmagic
386
wouldnt you like to know
Feb 13, 2006
  • Feb 13, 2006
I think MPH will be your best bet also . They have competive prices and do outstanding work.........look at all the guys here that them.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 13, 2006
  • Feb 13, 2006
price out VT engines too for your engine build. i have heard good things about both vt and MPH. and if i was building this motor i would go big bore or stock displacement. i know some people get ok results with strokers, but i feel the stroke is already to long compared to the bore in this motor and any longer will make for even more extreme rod angles ( not great for high rpm's) I know it's more money but i would get a aluminum block sleved and go big bore. it will be worth the extra money in the long run.
T
TGJ
1,049
  • Feb 13, 2006
There is only about 5 companies I would buy a performance modular motor from.
Boss 330 on Modular Depot
Modular Performance
Modular Power House
Renegade Racing
Steen Racing
I went through Renegade Racing for my 5.0L Big-Bore.
hognutz
1,940
albany, oregon
Feb 13, 2006
  • Feb 13, 2006
my .02 if 500hp is your goal and you will stick to it don't overbuy on the shortblock or buy stroker or big bore anything like that.
buy a shortblock good to 500hp ~2500. then boost it on the stock heads and cams. this will get you 500hp the most economical way.
all the other mods are nice but they start getting you into insane money and it is already going to be expensive as hell.
you could use the KB 1.7L. you may even consider the 2.2L if you don't mind getting a hood. you could also do a novi mongoose kit from MPH. I just think if your boosting on a budget spent you money on the bottom end and the blower. the power will be there.
1fast03pony
749
New york
Feb 13, 2006
  • Feb 13, 2006
Thanks for the info guys
Yes i was thinking about the 2.2l. the hood is not an issue but the money is insane. I wanted to go a little cheaper and the novi 2000 kit looks to suit my needs well- I wanted to save some dough and upgrade clutch, tires, and other misc. stuff like control arms. I dont want a blower and built motor with all that power and nowhere to go (and start breaking other things)
1fast03pony
749
New york
Feb 13, 2006
#10
  • Feb 13, 2006
  • #10
Ill keep this in mind. Great advice guys thanks
hognutz
1,940
albany, oregon
Feb 13, 2006
#11
  • Feb 13, 2006
  • #11
well to be honest if you ever hook up good with 500hp and stock rear and tranny you might wish you were not hooking up.
yeah the novi will saver you some coin and you will need it. I would at minimum buy a good rear cover and weld the tubes and torque boxes on the rear as it is not that much money and it might make your rear live longer.
you have the 3650 so if don't just beat on it hopefully the tranny will live. a centri also has leass torque down low so that help.
the down side the centri is the whole stock intake thing. so if you planed on buying a nice aftermaket intake as well that is where the KB stuff shines as you don't need it.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
D
supercharging my v6 4.0
  • dreamerv6stang
  • Jan 12, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 21, 2025
tovlux6
T
Bought an engine for my project
  • 2stroke1971
  • Jul 7, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2024
limp
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
