Engine Engine Dies Coasting To A Stop
Lynn812
I am new to the mustang family, I just purchased a 2014 CS mustang with manual transmission. My problem is the engine shuts of when I put the clutch in to slow down. It does not happen all of the time. For instance when you going down the highway and the light turns red I put the clutch in a coast to a stop and sometimes the engines dies. I have searched other forums and others have had the same problem. I have taken the car back to the dealer and he says I need to down shift as I come to a stop instead of coasting. Is this correct? Or is he being a turd and trying to pull the wool of my eyes? He says I am not driving it right.
The engine should just return to idle when you push the clutch in since it's now disconnected from the transmission (it should not die).
I'm not familiar with this issue though since I never experienced it when I had my 2012 GT. Did the other people who had this problem find a solution to it?
Sent from my Nexus 6 using Tapatalk
Well that sucks. It shouldn't die and it's unfortunate that they put the burden on you and suggest something that is not the solution to whatever the real problem is. Do you know what they have checked out? It might be worth sitting down with them and seeing what they have done so far.
I am not sure what all they have checked out. On a good note I made them take it to a performance shop to see if they can figure out what is wrong with it.
Reactions: skyline247
I had the same issue with my cam tune, i did the whole reset leave battery unhooked stuff, cleaned the throttle body real well, and replaced the stock air filter. That helped a ton, still would once in a while happen but stopped completely when i added new plugs to the mix.
