  • Fox Engine Swaparoo
Engine Engine Dieseling When Turned Off
  • Thread starter Thread starter Hinesja24
  • Start date Start date May 8, 2016
  • Tags Tags
    dieseling rough shut down
H
Hinesja24
  • May 8, 2016
Have a 302 bored 30 over. 650 demand carb. The guy I bought it from had it set up for 100 octane. Once I started putting 93 in it started dieseling. Do I just need to reset the timing?
Admin Dude
Jan 4, 1985
43,083
21,267
234
Box behind Walmart
May 8, 2016
  • May 8, 2016
Ummm... Wow. I'm not even sure where to begin.
The short answer is, "No" but lets get some dudes in here to ask the relevant questions: @TOOLOW91 @mikestang63
Reactions: TOOLOW91
TOOLOW91
20+ Year Stangneter
8,687
234
S.I.NY
May 8, 2016
  • May 8, 2016
Any other specs on the engine ? How handy are you with a timing light ? Borrow rent or buy one and start there . Check your timing and report back .
How was the engine setup for 100 octane ? The owner tell you that he just upped the timing or were the Pistons swapped with a piston to raise compression in the rebuild ?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 8, 2016
  • May 8, 2016
Try backing down your idle a bit. If your idle is set too high, the engine will continue to pull in and and fuel after shut down, which can sometimes cause a "run on" effect.
Reactions: TOOLOW91
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
May 8, 2016
  • May 8, 2016
As mentioned... we need more information on the setup before any suggestions can be made. Sounds like a high compression, high lift cam motor...
Why would you put 93 in a motor that you were told required 100?
J
jk294
14
northern Indiana
Jul 1, 2016
  • Jul 1, 2016
so, let me see if I understand correctly, you shut the car off and it continues to run?
I don't really think timing would have much to contribute on it's own. regardless, you should retard the timing a bit if you're going that big of a jump in fuel. but, when I hear dieseling in gasser engines, my first thought is carbon build up on either/both the pistons and the valves. and the timing advanced timing combined with the lower octane fuel isn't helping. more like exacerbating the issue. you could try over fueling it by a little bit. the fresh fuel will help to cool off the cylinder temperature. that'll help with pre-ignition/detonation/spark knok. with the cooler cylinder temps. that should help with either reducing the run on or eliminate it. down side with a carb is that it's SUPER easy to foul out your spark plugs.
but to be honest, I would recommend going down to your local dodge/jeep/chrysler dealer, going into parts, and getting some decarbonizer. run that through your engine. it should help with the run on.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jul 2, 2016
  • Jul 2, 2016
Well, considering this guy hasn't been seen around since making this thread more than 7-weeks ago, I'd say all the advice given has fallen on deaf ears?
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Jul 2, 2016
  • Jul 2, 2016
lead a horse to water Brian.....
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
