I have an 88 GT and the other day I parked the car turned off the key switch radio and other accessories turned off but not the engine had to pull the fuel pump relay to get it to shut off. The ECM also stays powered up also till you remove the ground So I figured key switch good ignition switch not soo much so I replaced the ignition switch but it still does the same thing
any ideas??
any ideas??
