Well I'm back on stangnet, but in a different part of town.
My Cobra swapped Gt is gone and i'm not longer a 4.6 guy.
Anyway I picked up a 95 Mustang GT from Iowa last weekend. I noticed a few days ago that it had a really bad tick<almost sounded as if it was a really bad exhaust leak.> This car has a E-303, which I knew from the start. I took off the valve cover to see if it was a loose rocker. To my supraise I found that whoever put the cam in didn't change anything other than the cam.
My question is before I take the motor apart what do you guys think i need to change str8-up? I'm positive its a lifter but what should I do? I'm sure other things may have got damage due to just changing the cam. Well let me know, thanks.
My Cobra swapped Gt is gone and i'm not longer a 4.6 guy.Anyway I picked up a 95 Mustang GT from Iowa last weekend. I noticed a few days ago that it had a really bad tick<almost sounded as if it was a really bad exhaust leak.> This car has a E-303, which I knew from the start. I took off the valve cover to see if it was a loose rocker. To my supraise I found that whoever put the cam in didn't change anything other than the cam.
