- Nov 27, 2009
- 59
- 0
- 6
hey guys, i am swapping out the old tired 5.0 out of my 89 gt for a freshly built one. when i had the new one build it was also ported, polished, bored .30 over, and a new cam put in. it also has new valve spring, valves, and roller rockers (1.6 to 1). the commpression should be around 10.5 to 1. also some long tube headers, a cromoly steel flywheel (lightend) and a 6 puck clutch kit. I was already sweapping the intake from the stock one to the one in the ford exploder, and was also thinking of getting a 70mm throttel body and MAF sensor. is there anything else i should think about getting? any help would be great.
. The 30lb injector I think is the right size and a tuner can adjust it, that way if you do throw on a better intake, larger maf etc you will be right there. again IMHO save getting beheaded
