Is it safe to lift a 5.0 via the upper/lower manifold bolt holes? Summit sells an engine lift plate that bolts to the lower, but I've got an engine leveler with 4 corner chains and I'm wondering if I could just bolt them straight to the 4 outer upper/lower manifold bolt holes without the engine lift plate (using grade 8 bolts of course). Will the lower manifold support the load? Including with a 5 speed trans and front accessories? I've already got grade 8 bolts holding the lower manifold to the heads. Anybody ever done this? It would sure be a lot simpler than getting at the accessory bolt holes.
