Engine Is DOA- New build- measuring for zero deck?
  • Thread starter Thread starter a91what
  • Start date Start date Mar 2, 2018
  • 3
  • 4
  • 5
First Prev 4 of 5 Next Last
Admin Dude
Jan 4, 1985
43,500
21,674
234
Box behind Walmart
Mar 10, 2018
#61
  • Mar 10, 2018
  • #61
I have not had a chance to research your request to spend to money (I'm sure you're aware why hehe) but initial thoughts are these:
9.5ish+ final compression
If this were a an already proven system for boost, I might recommend hyper pistons but it's an experiment so, "no".
The rest is easy. Zero balanced and light weight. It doesn't need to withstand 1000 HP, it needs to be able to safely handle 550 HP and operate at 450.
Make up ALL of your mass at the flywheel with billet steel (I've tried aluminim with PD blowers and an not a fan).
The stock ignition is MORE THAN ENOUGH to handle this job. I might ad a boost-a-spark just to keep the coil saturated in ALL electrical conditions.
What else? I think you have all the other pieces and parts. Studs for everything, if you want a girdle just pay the shipping. Oh...
Harmonic balancer. Don't be a cheap bastard. No under drive pulleys.
Admin Dude
Jan 4, 1985
43,500
21,674
234
Box behind Walmart
Mar 10, 2018
#62
  • Mar 10, 2018
  • #62
This may help you more than my last post. If nothing else, it will give you a starting comparison. These are nice kits and though the hype about their blocks is arguable, I think their rotating kits are pretty straight forward.
http://shop.dssracing.com/306_X5_rotating_kit_p/ra306x5.htm
Use it to help comparison shop with kits elsewhere knowing that all of these parts at least work well together.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 10, 2018
#63
  • Mar 10, 2018
  • #63
Oohhh yeah..... my pockets ain't that deep. Lol. Zero balance I will have to do some research on.... love the idea but grounds for divorce.... Lol.
Appreciate the input
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 10, 2018
#64
  • Mar 10, 2018
  • #64
Here is what i have so far.....
https://www.summitracing.com/parts/arp-154-4001
https://www.summitracing.com/parts/cgt-c5511-030
https://www.summitracing.com/parts/dms-8720-4030
https://www.summitracing.com/parts/arp-154-5408
the main stud kit could change based on main girdle or not.
https://www.summitracing.com/int/parts/kgb-mb529hp/overview/make/ford
https://www.summitracing.com/int/parts/kgb-cr804hpn/overview/make/ford
both these links are for kings hp series bearings..... not sure if i need something this robust in my application.
https://www.summitracing.com/parts/tsr-s9090-30
not sure if a ring package like this is needed but looks pretty good to me.
I calculated my CR to be just under 10:1 with a zero deck and 64cc on my gt40 heads... they have been milled flat twice so not sure what they really are cc wise but cant to too much smaller.
Anyone see an issue with what i have picked out? this may change of course..... i dont really need stuff this nice but hell why not build the big list.
RaggedGT
Mod Dude
Jul 20, 2014
4,761
3,220
203
Taylorsville ky
Mar 10, 2018
#65
  • Mar 10, 2018
  • #65
I’m a fan of Kings bearings, I’m also a fan of GT40’s-but is budget the only reason you are not Upgrading?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 10, 2018
#66
  • Mar 10, 2018
  • #66
The heads have ALOT of work done to them, full port large valves and drilled for 7/16 studs.... with 10psi it wont matter what head is bolted to the shortblock its gonna make power.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 10, 2018
#67
  • Mar 10, 2018
  • #67
I think i need to call tech support at summit or ?????? and get some advice I dont want to spend money on things i do not need.
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Mar 10, 2018
#68
  • Mar 10, 2018
  • #68
This may have already been said, but main studs and/or a girdle is going to mean an align hone on the mains. If your mains check out good, bolts will probably suffice, especially on a stock block.
Joe
Reactions: a91what
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 10, 2018
#69
  • Mar 10, 2018
  • #69
Main bolts are they TTY or can they be reused?
General karthief
Mod Dude
Aug 25, 2016
28,109
10,723
213
polk county florida
Mar 11, 2018
#70
  • Mar 11, 2018
  • #70
Mine are tty, there was some debate on here a while back about it, I would say at least 89 and newer for sure, I think the advantage to tty was you didn't have to go back and retorque. But I'm far from a mechanic, although I do have a 'shade tree'.
RangerJoe
2,560
1,146
184
Georgia
Mar 11, 2018
#71
  • Mar 11, 2018
  • #71
There is so much debate over this that I really do not know. I have a friend that reused his several years back and it is still doing fine. When I had my block checked and machined i was told my mains were fine and the machinist made no fuss over the block having the stock bolts in the mains at the time. However, a few months later I mentioned that I had swapped to main studs and he quickly told me that the studs would require a hone and that he had measured the mains using bolts, not studs.
Joe
General karthief
Mod Dude
Aug 25, 2016
28,109
10,723
213
polk county florida
Mar 11, 2018
#72
  • Mar 11, 2018
  • #72
To prove once again that I'm not very good at speed reading, I spoke about head bolts not mains, just call me a boob!
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 11, 2018
#73
  • Mar 11, 2018
  • #73
Gotcha so if I buy arp bolts I 'shouldn't' need a line hone. Studs I likely will..... depending on price I may just have it done anyway. What does something like this cost?
CarMichael Angelo
8,909
234
Birmingham, al
Mar 11, 2018
#74
  • Mar 11, 2018
  • #74
I've never heard of tty anything in a Windsor. I had tty head bolts in the 4.6.
I've always thought it a waste of money to buy main studs in a small Windsor. Considering that the block blows the whole main saddle out of it, what difference does it make how the crank is fastened to it after all of that junk is hanging out of the block?
RangerJoe
2,560
1,146
184
Georgia
Mar 11, 2018
#75
  • Mar 11, 2018
  • #75
When you take your block to the machinist, carry the hardware with you that you intend to run and have him measure and machine with it in place. Most times bolts to bolts do not require an align hone. And I want to say it ran around $400, but it's been a while.
Joe
General karthief
Mod Dude
Aug 25, 2016
28,109
10,723
213
polk county florida
Mar 11, 2018
#76
  • Mar 11, 2018
  • #76
I heard through the stang vine that steve found a block at some really sketchy back alley chop shop today but he had an appointment with a honey do list. Any bets on what he did ?
Grab the sketchy block and strip it down
Honey do list
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 11, 2018
#77
  • Mar 11, 2018
  • #77
Engine is home, I already stripped the heads off. Very very small ridge on the cylinder wall barely grabs a finger nail.
General karthief
Mod Dude
Aug 25, 2016
28,109
10,723
213
polk county florida
Mar 11, 2018
#78
  • Mar 11, 2018
  • #78
Do ya think that guy in the wal mart parking lot ever noticed his engine was gone?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 11, 2018
#79
  • Mar 11, 2018
  • #79
Nah we were done faster than it took to go shopping.
Reactions: General karthief
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 12, 2018
#80
  • Mar 12, 2018
  • #80
Got the pan off the block, factory trw pistons the crosshatching is good in all but one cylinder. That one cylinder looks like it was either damaged or had a fluid of some kind sitting in it for a LONG time. Way past the fingernail test in that bore, only thing I can do is to rip it apart and take the whole thing down to the machine shop and have them tell me what's up. If it can be fixed by going .03 over fine if it will require more than that the hunt will continue.
  • 3
  • 4
  • 5
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
