Engine is dying, replacement questions.
fox-gt
204
TN
My engine is on it last leg. The local junkyard has had some Lincoln Continentals in the past with V8's and an intake that looks like the stock 5.0 intake. If I pull an engine out of one of those and have it rebuilt, will all the stuff from my existing engine bolt up ok? Through some searching I noticed the cams are different in the 5.0 vs 5.0 HO Also, would you recommend a stroker kit for the rebuild? Am I better off going this route or should I just buy an already rebuilt 5.0 block? I don't have the money for a crate engine :(
