Engine Is Toast
  • Thread starter Thread starter BustedFox
  • Start date Start date Feb 17, 2018
First Prev 2 of 2
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Feb 24, 2018
#21
  • Feb 24, 2018
  • #21
BustedFox said:
It's the rings.
I might as well toss a stroker kit in it while its out of the car, right? I found 331 kits for about $1k. How much needs changed to go to the 331? MAF and injectors? Does the trickflow top end work well with the stroker kits?
With the right pistons, yes it will be fine. You will likely need to goto 30lb injectors and meter.
With that said, i'd just buy a shortblock from a reputable shop or have someone local build it for you.
If it was in your best interest to have the hci installed, it's for sure in your best interest to have someone build the shortblock.
That $1000 dollar kit is likely $2500+ built.
I'm also of the belief there is no point in a 331, three isn't any reason not to goto a 347.
nelzfoxes
5 Year Member
Aug 20, 2013
472
325
94
Feb 25, 2018
#22
  • Feb 25, 2018
  • #22
BustedFox said:
I have a 1988 GT with a trickflow top end kit on it. I've put about 2000 miles on the car since i installed the top end kit. I'm burning a ton of oil...the rings are gone.
Whats the best way to go about a rebuild?
Get a short block in a crate and then put my top end on it?
Have a speed shop go through my existing engine and replace worn parts?
This isn't a show or race car. I need something reliable that can handle 400 rwhp.
Once you determine that the bottom end is indeed gone, whatever you spend to rebuild it could be spent swapping to a 351. That last statement about not a show or race car / reliable 400 rwhp. For the past 3 weeks I have been beating the piss out of a lightning motor with a stock mustang ho camshaft and cobra roller rockers day in and day out. I just finished the motor swap super bowl weekend. I don’t have a number for you. Frankly if I just say 400 you would believe me (it’s not even close to 400). When I got it sideways hard leaving the Wawa last night and pulling from 80 to probably about a buck-ten on my way to work yesterday morning... if you see and hear it you would think around 400. Mine is not a show or race car either. What I’m saying is put a 351 in it enjoy the torque and tell everyone it’s a 347 that makes 550. That’s what I’m gonna do... am doing.
Reactions: Davedacarpainter
2000xp8
Aug 8, 2003
8,075
1,658
194
NJ
Feb 25, 2018
#23
  • Feb 25, 2018
  • #23
Sorry nelz, I think that is bad advice.
A 302 based engine will keep it simple and straight forward, for the most part it will be the same as the 302 he has already.
The 351 is a complex answer to a simple problem and based on the fact that he paid a shop to do the work, that's just more money in labor and parts that wouldn't really gain him anything other than a heavier engine.
Not sure the purpose in lying about the engine either, any real car guy that see's it will know it's not a 302 and if they don't know, is it really worth trying to fool them?
I'm not sure I understand your concept. You install a 351 that probably makes similar or less power than most h/c/I 302's, then try and fool people into not thinking it's not a 351?
Admin Dude
Jan 4, 1985
43,550
21,722
234
Box behind Walmart
Feb 25, 2018
#24
  • Feb 25, 2018
  • #24
Found another one to add to my collection from here: https://www.stangnet.com/mustang-forums/threads/why-ask-if-you-dont-want.902463/page-2#post-9104174
Noobz347 said:
400+ HP
They're all 400+ HP.
It's the bookface mentality. Just say whatever, doesn't matter. Accountability is the responsibility of others.
CarMichael Angelo
8,909
234
Birmingham, al
Feb 25, 2018
#25
  • Feb 25, 2018
  • #25
BustedFox said:
It's the rings.
You said the shop said the compression test checked out fine. How then can it be the rings? You are so gonna end up changing out a whole engine for a head gasket issue.
Reactions: 88LXSleeper and Boostedpimp
nelzfoxes
5 Year Member
Aug 20, 2013
472
325
94
Feb 25, 2018
#26
  • Feb 25, 2018
  • #26
It’s no problem. Just my opinion. I took a lightning motor that the previous owner put cobra roller rockers on. I took the roller cam from a mustang and put it in there. Then I cleaned the tops of those deep dish pistons. Now the engine is back together and running in the car. I love driving it. I love the way it pulls on the highway. Lie; don’t lie. I was just trying to relate my experience. I don’t actually tell anybody anything about my engine. My opinion is that the torque of the 351 is the real goal. Chase numbers if you like. I did gain something in the swap. I gained a lot. Everyone has an opinion.
88LXSleeper
146
56
48
Mar 2, 2018
#27
  • Mar 2, 2018
  • #27
A leak down test should always be done to determine proper cause of issues. My Spec Miata started smoking badly from oil, yeah blue smoke. Did compression test, numbers were not great but not awful. Did leak down test, air screaming out of every orifice from block. Found rings carbon glued into pistons grooves. Gotta prove engine is toast before condemning it.
First Prev 2 of 2
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
