engine noise
  • Thread starter Thread starter Slo 5.0
  • Start date Start date Jun 28, 2006
Slo 5.0
144
St. Louis
Jun 28, 2006
  • Jun 28, 2006
I took my car out for a drive and was getting on it a little here and there, then i noticed the car felt like it lost a little power but i didnt hear anything. A few hours later i went out and started it up and it sounded like the back of two big metal spoons were smacking each other. What did I break this time? I have to leave for school in 2 days. i need this fixed! tell me what you think it is. thanks
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 28, 2006
  • Jun 28, 2006
pull the valve covers off and take a look in there...or was it a knock like from the bottom end......
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 28, 2006
  • Jun 28, 2006
oh and love the sig lol
Slo 5.0
144
St. Louis
Jun 28, 2006
  • Jun 28, 2006
the sound is coming from somewhere on the passenger side, dont think its the bottom end. what stuff makes a noise like what i said.
Slo 5.0
144
St. Louis
Jun 28, 2006
  • Jun 28, 2006
thanks
Slo 5.0
144
St. Louis
Jun 28, 2006
  • Jun 28, 2006
i got the valve cover off, now what to do.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 28, 2006
  • Jun 28, 2006
wow your not fuggin around....look for broken spring's...loose rocker's..anything not normal. Maby adjust the rockers while your in there...Might just be a leaky header or a exhaust leak somewhere.
Slo 5.0
144
St. Louis
Jun 28, 2006
  • Jun 28, 2006
all of the springs look ok, i can wiggle the rockers a little. if i start the car will oil get all over, or will it be ok?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 28, 2006
  • Jun 28, 2006
should be ok for a little bit....oil will splash around a little
Slo 5.0
144
St. Louis
Jun 28, 2006
#10
  • Jun 28, 2006
  • #10
ill have to wait till tomorrow to start it, I dont want to make the neighbors mad.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 28, 2006
#11
  • Jun 28, 2006
  • #11
lol...stuff some socks in the tailpipes
fidstang
307
South Lansing
Jun 28, 2006
#12
  • Jun 28, 2006
  • #12
Pull out a couple of the pushrods and check to see if any are bent. Check your collector and exhaust make sure they're not hitting anyting metal. Check your motor mounts.
FORCED2DV8
458
Grand Rapids MI
Jun 28, 2006
#13
  • Jun 28, 2006
  • #13
It may be your rockers are loose, or it could be valve noise, you have to narrow it down. Or quite possibly the header bolts are loos and it s leaking there, Does it make the noise all the time, or just when you are excellerating ??
Slo 5.0
144
St. Louis
Jun 28, 2006
#14
  • Jun 28, 2006
  • #14
it makes noise all the time.
Slo 5.0
144
St. Louis
Jun 28, 2006
#15
  • Jun 28, 2006
  • #15
2 of the header bolts were a little loose but i tightened them and it is still making the noise.
RaceDvr50
121
Coon Rapids
Jun 28, 2006
#16
  • Jun 28, 2006
  • #16
Just a wild thought here, if you checked everything else have you checked the timing? I assume you know to pull the spout connector before setting it. Sometimes you can get a knock from too much advance however your knock sensor should retard the timing when this occurs I guess I'd check it to be sure. 10 degrees and see if it goes away. Otherwise I'd agree it sounds like valvetrain, bent pushrod banging around etc.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 29, 2006
#17
  • Jun 29, 2006
  • #17
Do we have Knock sensor's.....I didn't think we did
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
