Its appearing like my 351w is done... i was having a lot of trouble keeping it running and it broke down a few months ago. Brand new oil was almost black, and found lots of shavings on my magnetic drain plug. Took the oil filter off and found a couple large shavings, and also tested them to be magnetic. I took it a shop and they were going to run a compression check; but when they got around to it they heard loud grinding noises and said there's something wrong with the rotating assembly.
The motor didn't have that many miles on it, but was a cheap autozone rebuild that my dad put cam/heads on. It was already .060 over so a rebuild of it isn't an option. Additionally it was a hodgepodge of 71-74 parts, so it had low compression... essentially I'm not that sad tos ee it go.
I do hope my Trick Flow heads are okay, however.
Anyway, I'm looking into my options for replacement engines...whether I go with a full rebuilt engine, or a long or short block from Coast High Performance or another socal engine shop. My dad and I have done a heads/cam swap before, though I would pay a little extra if I could get a shop to do it for us. I can't go absolutely nuts though, budget would be $4-5k max, and I'd have to be pretty convinced this is going to last if I'm going to spend that mcuh.
My questions:
1) What would one expect to spend on a stock or close-to-stock 69/70 351w, rebuilt?
2) If I was to look at later model roller-type motors, woudl this change the price much? Which engines are best (strength, compression ratio, etc)?
3) Any thoughts on the choice of a) buying a short block, building it with my Trick Flow heads etc versus b) buying a long block and simply selling the Trick Flow heads to offset some of the difference?
4) Any SoCal shop recommendations?
Thanks!
Ben
My questions:
Thanks!
Ben
. I cant say how builders would handle it knowing your gonna be beating the s*** out of it because its fun. My engine builder(wont mention names) screwed me pretty good to the point that after 2 attempts I just built it myself.
