  • SN95 4.6L Mustang Tech
Engine Ping
  • Thread starter Thread starter rocketdog
  • Start date Start date Feb 16, 2007
1 of 2 Next Last
R
rocketdog
  • Feb 16, 2007
I have a 2001 Bullitt. I have developed an engine ping under WOT @ 4000rpm, right at it's peak power band. Anyone else encountered this problem and what, if any, was the fix?
Thanx,
DaveB
I thought my post addendum had been applied, my mistake. Anyway here is some more iportant info. I took the car to my dealer, (car dealer), they upgraded the PCM, checked the injectors and they gave it a clean bill of health.
ADRENLN
2,342
NJ
Feb 16, 2007
  • Feb 16, 2007
have you modified anything or added any parts lately? i didnt know that a vehicle that was tuned right could just develop an engine ping out of no where?
R
rocketdog
  • Feb 16, 2007
I had installed a K&N cold air kit a while ago but that shouldn't cause an engine ping. Would it?!
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 16, 2007
  • Feb 16, 2007
These 2 valves are very sensitive to spark knock (detonation). Normally detonation is relatively quiet, but if you can audibly hear detonation, that is not a good thing. I wouldn't go WOT anymore until you find the cause of this "ping".
Given that, I have seen the addition of CAI's cause weird idle problems and sometimes detonation. You said they "upgraded" the PCM. Did they just replace the PCM or do you mean they re-tuned it? You may need to slighly adjust your tune to alleviate the detonation, if that's in fact what you are experiencing.
Do you feel any kind of a miss?
R
rocketdog
  • Feb 16, 2007
It seems to idle pretty smoothly. From a stand still it accelerates really well. It's just when it's under "load" that the problem occurs. The dealer said that they installed a software upgrade for the car. I think I need to find a Dyno shop and run some tests to see what's up. I just don't have the tools to do a proper diagnostic and I don't trust dealerships.
Dusstbuster
I love meat more than anything! I just have a spec
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Feb 16, 2007
  • Feb 16, 2007
Fill it up with some higher than usual octane fuel til you find out too...
T
TripleBlk
312
Cape Canaveral FL
Feb 16, 2007
  • Feb 16, 2007
Thanx,
DaveB
Yeah, long term owner here . You have a stick or automatic ? I have a stick, and in situations such as leaving a toll booth while still rolling , found that dropping down a gear or two put the engine back into its what I call (non-lugging mode) Drop it down a gear or two, you are not gonna blow anything up !
sgarlic
3,085
Feb 16, 2007
  • Feb 16, 2007
Have you tried cleaning the MAF? I'd try that first, then if that doesn't fix it, think about going back to the dealership and asking them why it suddenly went from not pinging to pinging after the software upgrade.
joshheat25
871
Delaware
Feb 17, 2007
  • Feb 17, 2007
It's probobly the gas if you live up north where it's below 32 degrees! they put stuff in it so it wont freeze which causes the octane to be off!
the98stang
2,408
Clovis, CA
Feb 17, 2007
#10
  • Feb 17, 2007
  • #10
Most likely it's a bad batch of gas. Some 2v's will ping like crazy with 87 octane. Others will ping with 89 octane only. Just try different stations and octane rating's.
If that doesn't work, put the stock intake back on, and see if the ping goes away.
StangYellow
1,052
Feb 19, 2007
#11
  • Feb 19, 2007
  • #11
Does your car lose power, or just make a pinging noise? It could be as simple as an increase in octane. Have you changed the plugs to something other than stock (heat range, length)?
2013 Geee T
805
Oak Park, CA
Feb 19, 2007
#12
  • Feb 19, 2007
  • #12
Thats what I was going to say. Ive heard countless people say the oil from a K&N can get on the MAF sensor wire and causing pinging.
My car tends to ping between shifts on hot days for some reason. Wierd.
MaxedGT
304
Surrey BC Canada
Feb 20, 2007
#13
  • Feb 20, 2007
  • #13
Try it with the stock intake. Some of the cold air intakes will cause a lean condition, due to the way the air flowas through the maf sensor. Also over oiling the K&N will contaminate the maf sensor and make cleaning it necesssary. If the cold air intake is causing the problem, it won't be covered by warranty. So go back to stock before going back to the dealer.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 20, 2007
#14
  • Feb 20, 2007
  • #14
it sounds like they already reprogramed the processor for TSB 01-12-3 so I would try it with the stock intake and then if it still don't go away try to reset the KAM ( keep alive memory) then watch the long and short term fuel trims at idle.. Open loop operation is altered by what is learned by the PCM in closed loop, if something is messing with the feedback from the 02 sensors or the MAF and IAT readings then you could possibly run into a lean WOT
If it goes away with the stock intake I would get a custom tune and then reinstall your intake.
R
rocketdog
#15
  • Feb 20, 2007
  • #15
It's a stick. And I'm located in SoCal. The ping occurs when I go WOT and hit about 4000rpm. Whether I downshift or not. I guess the good thing is that it's consistant.
R
rocketdog
#16
  • Feb 20, 2007
  • #16
I've changed the ACT sensor and I do have my eye on the MAF next. It makes sense. I've run serveral tanks of gas through it so I think that I can eliminate a fuel problem.
Since I took the car to the dealer and run a little, the ping "seems" to be diminishing a bit. I'll know for sure on my way home tonight and pull that hill. Also, I'm going to run another tank of fuel through it.
Dusstbuster
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Feb 20, 2007
#17
  • Feb 20, 2007
  • #17
what octane?
R
rocketdog
#18
  • Feb 20, 2007
  • #18
The recommended 89 proof. I've used the highest available here, (91), but the problem persists.
R
rocketdog
#19
  • Feb 20, 2007
  • #19
I think I've found something!
Check out this little tidbit I found in the Newbies strings.
http://www.stangnet.com/images/stories/docs/sn95_TSBs/01-12-03.pdf
Sound familiar?
MaxedGT
304
Surrey BC Canada
Feb 20, 2007
#20
  • Feb 20, 2007
  • #20
Sound familiar?
It says 01 Bullit GT. Listen to SVtech.
You already had the program update for your car.
1 of 2 Next Last
Tuning help! - HEGO 2 @ 64 volts!!!
  • VenomousISA
  • Feb 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Feb 26, 2025
VenomousISA
D
Fuel Weird ping at high RPM/ high load
  • daniel_heigher
  • Mar 24, 2020
2K
SN95 4.6L Mustang Tech Mar 25, 2020
wmburns
R
Electrical Hard to Start, Rough Idle, Won't Rev Up/Barely Any Power to Drive
  • rdmcalli
  • Dec 5, 2021
7K
Fox 5.0 Mustang Tech Sep 3, 2022
Mindseye007
J
*New guy* Microsquirt questions regarding required engine info.
  • jack.stand.racing
  • Sep 23, 2020
  • Digital Self-tuning Forum
3K
Digital Self-tuning Forum Sep 24, 2020
jack.stand.racing
J
For Sale 2002 Stage 2 (supercharged) Roush mustang
  • Mr.Roush02
  • Oct 14, 2020
6K
SN95 Mustangs For Sale (1994-04) Dec 13, 2020
austin3749
A
