I know for most cams there is a recommended compression ratio, for instances Ford's X-cam it's 9.0:1 to 10.5:1. What happens if your compression ratio is lower (8:7:1) than the recommended?
Also, separate question what happens if someone installs the piston with the reference point on the piston facing the opposite direction than front of the engine block. However, all pistons are facing the opposite direction.
