Engine runs for about 5 seconds
  • Thread starter Thread starter Sample36
  • Start date Start date May 9, 2006
Sample36
  • May 9, 2006
Car ran perfect no issues...the fuel pump quit so i replaced it...this is when all the problems started...I jumped the fuel pump out to prime the system and i touched the wrong lead and had a few sparks.. i primed the sytem and started the car. Car started imediately and revved up to 1200rpm, leveled out at 1000rpm then quits. I thought it was a faulty fuel pump so I put another new one in with the same results. I hooked up the fuel pump direct still no improvement...any suggestions..
1988 5.0L Mustang
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
May 9, 2006
  • May 9, 2006
wow...sparks while putting in a fuel pump are not a good thing. i would have soiled my britches. dont really know what to tell you unless the relay is bad and when you turn the key to "start" it primes the fuel system but in "run" the fuel pump shuts itself off and it just uses up all the gas in the lines. kind of wierd actually, but thats the only thing i could think of. maybe someone who has had this problem can help out.
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
May 9, 2006
  • May 9, 2006
Did you do any upgrades or did this problem just occur out of nowhere on a perfectly running car?
Sample36
  • May 9, 2006
No upgrades just a new fuel pump.... I think when i touched the wrong leads together i screwed up the computer...i am buying a code reader tonight to see if i have any issues there
Ozz
3,514
66
109
Canton, MI
May 9, 2006
  • May 9, 2006
What fuel pump did you put in?
What is your engine setup?
Sample36
  • May 9, 2006
Stock Fuel Pump intank
Ozz
3,514
66
109
Canton, MI
May 9, 2006
  • May 9, 2006
Wow that's weird. Your engine setup is mild enough for the pump to support, right?
Did you check your fuel filter?
HISSIN50
34
129
May 10, 2006
  • May 10, 2006
I'm not sure what you jumped or where, but check the fusible link (18 AWG IIRC) for the fuel pump.
You can also probe the FP relay socket during the priming and note the values. If you have three 12 volt terminals and one ground, you should be good.
If you're missing the common terminal current, the relay has nothing to pass to the pump (the link provides power to the common terminal).
Good luck.
Sample36
  • May 10, 2006
No mods only headers and KN filter
Sample36
#10
  • May 10, 2006
  • #10
By passed the relay with no luck. Checking TPS tonight
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
