Engine Runs Hotter???
they can run hotter because of the increased latent heat from the blower case as well as the increased inlet temperature. usually upgrading to a larger or more efficient radiator with a lower temp t-stat is a good idea. but definately make sure your motor is in proper running condition.
sure it makes the engine bay temps hotter, which is normal for most(if not all) forced induction apparatus'.
though if you coolant/oil temps are alot hotter as well, than that would be something to look into.
