- Dec 29, 2003
- 68
- 0
- 0
I have a 1984 302 in my 1966. When I try to crank the car it appears to turn very slowly even with a new battery, starter and cables. With a solid lifters can they have too much tension on them from tightening.
I don't understand this statement. Did you tighten the rocker nuts too much? Are you talking about spring pressure? My guess is too much advance on your timing. Or a poor ground. Or too much compression.candyapple said:With a solid lifters can they have too much tension on them from tightening.
