Engine sometimes dies when coming off the throttle
  • Thread starter Thread starter buildit
  • Start date Start date Sep 5, 2011
buildit
  • Sep 5, 2011
5.0L, TrickFlow Top End Kit, 75 mm TB/MAF
I had my car dyno tuned to make sure I wasn't lean ( I was a little). They corrected that with the chip, but ever since when I come off the gas at speed like to turn into my subdivision, the car sometimes dies completely.
I did the IAC test (got the car warm, unplugged it, see if it makes any difference). The idle did change when I did that, and got a little erratic.
I have set the TPS voltage previously (~.98) , haven't checked that again yet.
One other detail, while I was at the tuner we found that one of the injectors had quit...header for that cylinder was cold. I had 24# injectors in it. The tuner didn't have any 24#, so we we replaced them all with 30# and he corrected the MAF in the tune. It dyno'd fine after that and it ran ok coming home.
Any ideas?
Thanks!
Rick 91GT
Mustang Master
95
99
PA
Sep 5, 2011
  • Sep 5, 2011
Personally Id swap out the one injector.... I would play with the idle screw to see if you can bump it up just a little to get the TB open a little more, you may have to reset the tps I like to keep them around .92-.95 so it never sees 1v. Still could be the IAC.....
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 5, 2011
  • Sep 5, 2011
See the "Surging Idle Checklist for help with all your idle/stall problems.
The quick and easy way to dump the codes is in there too, and all you need to do it is a paper clip! The first two posts contain all the fixes & updates. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
Dino Dino Bambino
1,673
90
79
Cyprus
Sep 5, 2011
  • Sep 5, 2011
A faulty VSS could cause the engine to stall when coming off the throttle so you might want to look into that. The IAC is often falsely blamed for the problem so beware. You may replace the IAC and find that the problem's still there.
buildit
  • Sep 5, 2011
Thanks, guys.....I did replace all the injectors with 30# (i fixed my original post to be clearer). And I do have the VSS hooked up. This just started after the tune.....never had an issue with it before.
I'll try the base idle reset, thanks for the tip.
Any other thoughts?
Appreciate it!
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Sep 8, 2011
  • Sep 8, 2011
There are several things the tuner can do , and some things you can do as well , cracking the throttle plate to raise the idle speed just a little will help , the tuner can also add spark at idle , lean out the idle mixture just a little , and even clocking the MAF could possibly help depending on the set up you have
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
