Engine start-up after long 6 month sleep?
geostang351
946
Danb., CT
Hey guys, what do you do to prepare your engine after it sits all winter with no start up at all durng the 6 months it sleeps? Do you pull the distributor and prime the oil pump? If so, what do you hook-up to the drill; an extended rod?
Thanks,
Geo
Six months isn't really very long for an engine to sit. I usually just start it up!
Typically, I have to charge the battery first, but you get the idea.
If the car has sat for a year or two (and yes, I have let cars sit that long before) I pull the coil wire and crank the engine for ten seconds at a time, resting five seconds between cranks. I do this until I either see the oil pressure coming up, or ten or twelve times (in other words, until I get impatient).
Then I connect the coil wire, pump it three times, and fire it up.
So far, this hasn't done any damage (that I know of) and it's a lot easier than pulling the dizzy to prime the pump.
Wayne.
one recommendation i would make is before you put your car away for the winter, to put some stabul fuel stabilizer in the tank and let the car run for a while to let it circulate through out the fuel system, to prevent varnish from forming in your carb. also, after u get it started, obviously change the oil.
