OK, I'm nearly ready to fire her up ('66 289 C code), and I'm thinking you guys must have seen every problem there is. Any advice? In particular:
Is the oil pump self priming? If not, how do I fill it up?
I need to get oil around the engine before I make proper start, I have been told that I can spin the oil pump over with a power drill, if I take the distributor out. Is this correct? What kind of drive do I need to fabricate the do this?
How do I prime the fuel system? The gas tank has a gallon or two of fresh unleaded in it, but I need to get the gas into the carb to prevent a lot of unecessary cranking before she fires. Any tips?
The benefit of your collective wisdom would be appreciated.
