- Apr 8, 2007
- 11
- 0
- 2
Thanks for any help with my situation. Here is an example scenario of the problem I am having (car is a 93 GT, bone stock except for removal of air silencer and addition of K&N air filter, approximately 90,000 miles, 5spd transmission):
Scenario: Cruising on the freeway at 70mph, 2000rpm, 5th gear. Drop into fourth and punch accelerator to floor and car will immediately begin to stumble and struggle to accelerate or will pull hard to approximately 4200rpm and then stumble really bad. If I slowly ease up on the accelerator when the engine begins to stumble in either case, it will eventually begin to pull strongly again up to the point that the built in fuel cut-off kicks in but only if I press down on the gas pedal slowly. Car will pull strong and steady to approximately 6,000rpm in every gear as long as I begin the acceleration by pressing down on the gas pedal very slowly. Flooring it at any point in the rpm range of any gear causes minor to major stumbling and bogging down. Any solutions or suggestions? Is this a normal problem? Am I expecting too much of a stock setup?
