Engine stutter with new MSD SC wires
chip97
I purchased a new set of MSD Super Conducter wires for my 3.8. Prior to installation, I had no problems with the ignition. After installation, the engine would stutter and stumble under mild acceleration, I would get a check engine light. Using my Actron Code Scanner, I pulled up a "P0340 engine malfunction, bank 1, camshaft postion sensor". Well, after numerous attempts to correct the problem, I'm perplexed. When I re-install the OEM plug wires, the engine runs fine. I've replaced the Camshaft Position Sensor, the Crank Position Sensor, installed a new coil pack, cleaned and inspected everything I can find. Of course, the Ford Service Manual does not cover this problem. Mods: Steeda Under Drive Pulley kit, MAC CAI, Granatelli Motorsports 150 GPH Fuel Pump, Optima Red Top battery. I have 24 years experience as a Navy Aircraft Technician, 30 years playing with cars and I can't help but think I am missing something really obvious. Does anybody have any ideas, suggestions. OBTW, MSD replaced my plug wires twice, they have been very generous. MSD had no suggestions for me.
I had the exact same problem on my 97. I tried a million different solutions to find the ONLY solution was to use the stock wires. I tried 3 brands of aftermarket wires, new cam sensors, a different coil pack and none would solve the problem.
I believe it's from RF's coming off the wires effecting the cam sensor.
