Engine Stuttering?
  • Thread starter Thread starter jonv
  • Start date Start date Oct 16, 2005
J
jonv
24
Springfield, TN
Oct 16, 2005
  • Oct 16, 2005
Hey there, I've got a 1994 5.0 GT, and I'm having a few problems with the engine stuttering/hesitating.
Firstly, what I've done is replace the spark plugs, plug wires, distributor cap, rotary button, and the fuel filter.
I'm not exactly car savvy, so I don't know what I need to try next.
Basically, the problem is, while I'm driving down the road accelerating my engine will heistate, and it will miss. Also, when I start the engine it doesnt idle up to 1000 RPMs right away, it acts as though it wants to die. I have to give it gas to get it idled properly.
I'm just wondering what the next step would be to troubleshoot this issue and get it solved.
Thanks in advance!
legalize420
1,541
South Florida
Oct 16, 2005
  • Oct 16, 2005
check firing order. mine did the same thing when i crossed #2 and #3 wires.
J
jonv
24
Springfield, TN
Oct 16, 2005
  • Oct 16, 2005
Just ran outside and checked it. All seemed fine. Any other suggestions?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Oct 16, 2005
  • Oct 16, 2005
Well, considering what you have done, that eleminates the plug and wire issues. Any codes???
I would check the TPS voltage and do a sweep and check to see that the volatage makes a clean climb consistant with the movment of the throttle plate. No dead spots or spikes should be detected.
Then I would check the MAF to be sure it is clean. Check it's output voltage to be sure it is reading as well as being sure it is getting a good power and ground. Also, check to see if these sensors are getting good contact to the computer.
A vaccume leak can cause these things too but not as likley. Are you getting exaust gas in the radiator?
ARMAGEDON
100
Oct 16, 2005
  • Oct 16, 2005
I had that problem for a year and replaced a lot of parts, spent a lot of $ and time. I finally replaced the whole distributor and so far (10 hrs. of drive time) the problem has not shown itself. The PIP or magnetic pickup on the end of the distr. goes bad. Just replace the whole thing. It only takes 5 minutes.
J
jonv
24
Springfield, TN
Oct 16, 2005
  • Oct 16, 2005
Would changing out the ignition coil help any?
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
