  • 1994 - 1995 Specific Tech
Engine swap
  • Thread starter Thread starter Kidx
  • Start date Start date Jun 15, 2005
K
Kidx
  • Jun 15, 2005
The only car i have ever owned was an 89' 5.0 GT, i bought it when i was 16. The car was basically stock, except for small mods like headers and H pipe, K&N filter, etc. The engine started to screw up about a year ago (2 years after buying the car), and i pulled the engine and transmission, and had the engine overhauled and upgraded. Sence the engine bay was accessable, i decided to pull everything off, sand and POR-15 coat everything, along with upgrading the suspension with new hyperflex bushings, shocks, struts, etc. Upon removing the fenders and font clip, it was obvious the car was shot...the guy who i bought it from had obviously crashed it, and put new plastics over it, and where the front K member mounts it was rusted so bad, it desentegrated with minimal hammering. The thing is, the body on the car is immaculant, but it was hiding fatal flaws within...So basically i am looking for a rolling chassis, i have a perfect engine that has been sittining in a crate in my garage for a year now, and a solid AOD and rear end. I was wondering if the 302 H.O (now a 306) from my 89 GT would be able to bolt right into a 94-95 GT rolling chassis. Although my heart will always be with the fox body mustang, it would be nice to have the upgraded suspension and interior of the later model. Thanks alot for all your advice
donjohn
1,757
Irvine - Southern California
Jun 15, 2005
  • Jun 15, 2005
i don't see why it wouldn't, same engine. some of the accessories are different so you'd have to pick whether or not you wanted to keep the fox or go w/ the sn95 setup
u should post some pics of the old fox, sounds like a nice car
1slow95
1,797
ohio
Jun 15, 2005
  • Jun 15, 2005
The accessory brackets are different, but Im not sure if the accessories are different or not. I don't know if you can use the fox accessories on an SN95.
The throttle body and air intake are different, but all you would need is a fox throttle cable since you have everything else. You may have to make your own CAI, or a fox CAI might work.
I think the distributor/TFI are different, too.
AFIK, everything else is pretty much the same.
J
jasonlee0704
219
Kansas City, MO
Jun 15, 2005
  • Jun 15, 2005
If you don't want to spend money on a CAI, just get a 94-95 V6 air intake tube (by which I mean the big molded rubber hose between the MAF and the the throttle body), it fits a Fox 5.0L setup almost perfectly.
The alternator, at least, is definitely different between the Fox and the SN95 5.0Ls.
I could be wrong, but I don't think the Fox headers will fit in a SN95.
9
95_5.0_stang
172
Lansing, MI.
Jun 15, 2005
  • Jun 15, 2005
I am in the middle of a v8/5 speed swap and I used the engine out of a 88' and put it in my 95' which used to be a v6/auto. The 88' had headers on it when I bought it, and they fit in my 95' so I think he'll be ok.
K
Kidx
  • Jun 16, 2005
Thanks guys
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Foxbody Intro
  • 5.0Sucio
  • May 26, 2026
  • The Welcome Wagon
The Welcome Wagon May 26, 2026
