Engine Temp
  • Thread starter Thread starter dbdragracing
  • Start date Start date Sep 11, 2005
dbdragracing
397
Sep 11, 2005
  • Sep 11, 2005
I just purchased this '89 Mustang GT about a month ago. It seems to run great, but the temperature gauge and tach don't work. I just want to make sure I'm not hurting the engine. I drove it around about an hour today (80 degrees outside) getting in and out of the gas and then put it back in the garage. Three hours later I went out and the intake manifold was still very hot to the touch (hood had been closed)...is this normal or should it be a lot cooler? Also, is my stock temperature gauge electric or manual? How often should you replace your termostat? Thanks for the help.
HISSIN50
34
129
Sep 11, 2005
  • Sep 11, 2005
Get a real gauge - your stock gauge is about as accurate as the rest of ours (which do work). You definately do want a gauge.
The stocker temp gauge is electric. The sender is behind the dizzy in the lower intake manifold.
If you dont know the pedigree of the car, I would replace the stat at some point here, just so you know what you have. I prefer the Mr. Gasket line of stats.
Good luck and enjoy the new ride.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Sep 11, 2005
  • Sep 11, 2005
The man know's his stuff..I'd follow his advice.
Lyncher
434
  • Sep 11, 2005
he definatly seems to know his ****
A
Allforspeed
264
  • Sep 11, 2005
those guages suk anyway, i have totally chased problems that weren't there just cause the guages are so inaccurate, i vote just get autometer replacements on ebay and dont even try to fix the stock ones
also, it is totally normal for the intake to be hot if the hood was closed a few hours after if its a normal day outside, expecially if your car is a dark color, unless you heard pinging while driving it and then coolant boiled out once you parked it, i wouldn't worry,
thermostats should last a long time, they are cheap and easy to replace though, i run a 180' thermo and it works perfect, though my car is still pretty stock
A
Allforspeed
264
  • Sep 11, 2005
also, hissin is the boss of life, he has helped me out on virtually every problem i have had with my car
thanks bro!!! your the man! cheeers
dbdragracing
397
Sep 11, 2005
  • Sep 11, 2005
Heck yeah! I love this website. The car sounds and runs fine. I'm looking at Autometer gauges right now....Im just going to replace every gauge and then add some! I will order a new thermostat when I order the gauges. Thanks for the help.
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
M
Engine Throttle sticking
  • Magnet86
  • Feb 5, 2025
Fox 5.0 Mustang Tech Apr 1, 2025
General karthief
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
