Engine Temp ??
  • Thread starter Thread starter asecretfile
  • Start date Start date Oct 29, 2007
asecretfile
228
  • Oct 29, 2007
87 GT all summer when it was 90+ degrees engine temp stays nice and cool but now driving to work its 38 degrees car starts to overheat. You'd think it would be the other way around. Fluid level is good also
Needs new t-stat maybe?
Thanks
302RollinHard
Columbus, OH
Oct 29, 2007
  • Oct 29, 2007
You could let the engine idle with the rad cap off and see if the coolant starts flowing to indicate t-stat opening. Could it be that you started using the heater and maybe your heater core had some air in it?
Any leaks anywhere???
ninety15.0
1,336
  • Oct 29, 2007
Thats a good point...you have probably started using your heater. I would burp/check the system for air bubbles. Might as well take the t-stat out and check its function in a pot of hot water on the stove and a cooks thermometer. If its not doing what its supposed to then buy a nicer Mr. Gasket t-stat. good luck man
ShortThrow50
923
Pa
Oct 29, 2007
  • Oct 29, 2007
Ive never really had to burp a system but hey I understand some peoples cars are different. As long as you have enough fluid in your resivoir it should siphon out what it needs. Where do you live? Did it maybe go down to freezing last night and possible you didnt have enough coolant mixed. Could be a blockage from ice in your radiator.
asecretfile
228
  • Oct 29, 2007
Thanks for the fast replies
The car isnt leaking anything but I did use the heater this morning for the first time in a good while and when I turned the heater off the temp would creep down slowly but not much
asecretfile
228
  • Oct 29, 2007
Im in Atlanta. The temp outside was around 39 for the low but the car stays in the garage with the garage door closed. I do have a half and half mixture though in it to prepare for the fall/winter
ShortThrow50
923
Pa
Oct 29, 2007
  • Oct 29, 2007
well then, thats not the problem. Did you check your fan clutch when the car was overheating? When its overheating, pop the hood with the engine running, check that the thing is spinning really fast when you hit the throttle manually at the throttle body. That fan should start to ROAR big time with the car overheating
asecretfile
228
  • Oct 29, 2007
well its got an electric fan...did ok last winter...ran not too hot but hotter than I was comfortable with
ShortThrow50
923
Pa
Oct 29, 2007
  • Oct 29, 2007
I guess you already checked then to see if that baby is pumpin a good amount of air through the rad then
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
