Engine weight?
  • Thread starter Thread starter tjm73
  • Start date Start date Jun 21, 2005
T
tjm73
2,418
Rush, NY
Jun 21, 2005
  • Jun 21, 2005
Anyone know what a 5.0 shortblock weighs? No heads, no intake.... just a block, cam, crank, rods, timing chain, rings, timing cover, water pump and so forth.
D
Deleted member 87397
Jun 22, 2005
  • Jun 22, 2005
I have a book that would tell me probably, but I'm at work right now. I'll try and look it up later.
Rick 91GT
Mustang Master
95
99
PA
Jun 22, 2005
  • Jun 22, 2005
about 150#-175#
T
tjm73
2,418
Rush, NY
Jun 22, 2005
  • Jun 22, 2005
Cool. Thanks.
I'm trying to estimate how much a 302 with AFR heads and a Weiand Stealth Intake with a 650cfm carb would weigh. No A/C or P/S. It'd only have an alternator.
nosmatt
1,356
Bass Lake, Ca
Jun 22, 2005
  • Jun 22, 2005
a fully dressed efi 5.0 weighs right about 450 with iron heads (no accesories) i would say 375-400 for your combo.
Zero_chance
1,244
Maricopa, AZ
Jun 23, 2005
  • Jun 23, 2005
A bare block alone is listed in MU catalog at 150 lbs. Cant say Ive ever put one on a scale to confirm though...
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Jun 23, 2005
  • Jun 23, 2005
Rick 91GT said:
about 150#-175#
Yea,thats about right.
I can pick up and carry a 302 block for a short ways,bout as heavy as a C4 (a C4 is +/-80lbs).
The cranks is heavy piece,but not over 50lbs I would say.
Pistons and rods...I dont know,maybe 3lbs each per piston/rod combo?
And the rest is pretty light,at most only 10-20 more lbs al toghter.
Rick 91GT
Mustang Master
95
99
PA
Jun 23, 2005
  • Jun 23, 2005
The bare block is about 75#....
I build motors for customers all across the country, most stroker motors are a little heavier depending on the internal combo.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jun 23, 2005
  • Jun 23, 2005
And then you pick up your nuts after they drop out of your nutsack
T
tjm73
2,418
Rush, NY
Jun 23, 2005
#10
  • Jun 23, 2005
  • #10
38.2 lbs per the 2005 FRPP catalog.
AvalancheSVT
573
37
49
Jun 23, 2005
#11
  • Jun 23, 2005
  • #11
ford racing 302 with aluminum heads weighs in at like 419Lbs.
prolly 350-375 sans heads. 150 is WAY too light.
T
tjm73
2,418
Rush, NY
Jun 23, 2005
#12
  • Jun 23, 2005
  • #12
I've done a little research and I wanted to share the findings.
First the block. FRPP catalog says the B50 Sportsman block weight approx 10 lbs more than a production block. Summit lists the B50 block at 165 lbs. So About 155 lbs. it is what the production block weighs.
Second the crank. Again from the FRPP catalog, as I said earlier, 38.2 lbs.
Next rods. Each rod weighs about 585 grams. That equals 1.29 lbs ea.
Pistons. These vary a lot. But about 600 grams is a solid, accurate guestimate. Which is about 1.3 lbs ea.
Add it up and you get about 215 lbs
Add about 5-8 lbs for bearings and gaskets.
15 lbs for an aluminum carb intake.
I found a post where someone said AFR225's weighed 38 lbs each. So AFR185's probably weigh in at 40 lbs ea. Give or take a little.
Not known is camshaft weight, timing chain weight, front cover weight, oil pan weight, or total valve train weight.
Rick 91GT
Mustang Master
95
99
PA
Jun 23, 2005
#13
  • Jun 23, 2005
  • #13
I just got in a set of Probe Forged pistons, SCAT 4340 rods, SCAT 9000 series cast crank, rings, bearings and all the packaging 77lbs (50 pounds is the aftermarket stroker crank)
I'll weigh a stock block tonight and post the results, I thought empty it was only 75 pounds ( mI throw them around pretty good), cam is 6-8, pushrods, 1-2, etc.. I'll post the weight of a DART Iron Eagle as well.
My fully ported AFR 225's, with lightened goodies weigh 35# each
T
tjm73
2,418
Rush, NY
Jun 23, 2005
#14
  • Jun 23, 2005
  • #14
I think this is turning out to be a great tech thread.
T
tjm73
2,418
Rush, NY
Jun 23, 2005
#15
  • Jun 23, 2005
  • #15
Can't forget a damper (M-6316-A50 = OEM) is 12.1 lbs. The 28.2 oz M-6316-C351 (for 302/351W) is 11.5 lbs.
Water pump = ? Anyone?
And flywheel. Can't find spec for them either.
What's T5 weight BTW? And how much does a clutch weight?
fly4spd
118
Las Vegas & Reno
Jun 23, 2005
#16
  • Jun 23, 2005
  • #16
t5 is 105 lbs dry, I'm pretty sure
Rick 91GT
Mustang Master
95
99
PA
Jun 24, 2005
#17
  • Jun 24, 2005
  • #17
128 lbs for a stock 86 block and main caps, so a shortblock will be in the 180 range..
T
tjm73
2,418
Rush, NY
Jun 24, 2005
#18
  • Jun 24, 2005
  • #18
Damn! Aren't the '86-up blocks all the same? Something about the '85 makes it a little different I think.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
New Project Car - The Civil War Mustang
  • TTSaleen
  • Jul 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:33 PM
AeroCoupe
O
Timing guide
  • oilleak1000
  • Oct 10, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 10, 2026
oilleak1000
O
