Well... my harmonic balancer came apart!! I think it all started with the front main seal leaking, and oil might have gotten between on the rubber seal between the inner and outer ring on the HB. This happened last Wednesday, I pulled in the driveway after playing cat & mouse with my dad in his Cobra, it came apart and everything started vibrating! It flung the outer ring to the timing cover, grinding a 2"x1/2" hole in it, and wore off some of the bolt hole on the bottom of the water pump. Timing cover will be fixed with an 1/8 aluminum plate welded over the hole. And yes, I have an aluminum welder.
Parts are coming from www.50resto.com
I'm getting a new Ford water pump, 180 degree Mr. Gasket T-stat, PCV valve, new seals, etc
I'm looking at either a stock replacement HB, or the 28oz or 50oz "Sportsman" HB. Would the 28oz or 50oz sporsman work for a street driven car, if so, which is better? Since the prices are in the same range, money won't be an issue. I just want the one that is reliable, will work good on the street and (if possible) give me a little more performance.
Stock: http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-6316A%20%20%20%20%20%201&comp=LRS
50oz sportsman: http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=M6316B50%20%20%20%20%20%20%201&comp=LRS
28oz sportsman: http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=M6316J351%20%20%20%20%20%201&comp=LRS
Last but not least- are the Steeda X2 ball joints worth the $20 more than stock ones, and do they make a difference? I've got 1 1/2" H&R springs.
Thanks for the help
Wade
Thanks for the help
Wade
