I just installed B cam, GT40 heads and a 95 cobra intake on my 95 gt (AODE). I have the base timing set at 12 degrees and i cant find vacuum leaks, smog and Egr are deleted. the car revs fine and pulls strong, but it dies at idle, I adjusted the screw on my throttle body to get it to idle higher and this made it stay on but when i put it in drive it dies, also It seems like its idling better in the cold once the engine heats up it dies easier. what direction should i look into first, how do you adjust idle on a sn95?
