Engine wont pull over 3k
Fastcat
582
St. Louis
Ok Engine is all together, idles fine and sounds great. but when I get to 3k rpms the engine stops pulling almost completely and it rearely lights up the tires. What could this be? Could it be a timing issue. It seems like my car doesnt like 10* it likes WAY more than that (yes I installed the cam and timing chain correctly... Im absolutely POSITIVE).
This is how the balancer looks
10 llllll 20 llllll 30 llllll 0BTC lllll (cant read anything past this point)
I have a mark on the 10* part of the balancer and the engine runs like crap and misses at that position. But If I set it at anywhere after the part were I "cant read..." It idles and sounds fine. IS there another 10* mark after the 0BTC?
Spout was out when checking timing
Did you drop the distributor in in the right place. Being a tooth off is enough to cause your symptoms. The car should run fine at 10*. Set it back up on TDC and see where the rotor points under the cap. Should be pointing at #1 on the cap. Also check your firing order. :nice:
Ditto....also do as stated above and make sure your wires are connected properly.
clean your mass air flow sensor. my was doing the same thing until i tok apart the mass air and cleaned the two little wires and then it ran great. also did it when my computer chip went bad.
