Build Thread Enola- Finishing touches
  • Thread starter Thread starter a91what
  • Start date Start date May 31, 2015
  • Tags Tags
    393 4r70w megasquirt ms3 ms3pro turbo watermeth injection
  • 113
  • 114
  • 115
  • 116
  • 117
  • 239
First Prev 115 of 239 Next Last
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 22, 2018
#2,281
  • Feb 22, 2018
  • #2,281
The mounts are new, and the motor does not have the bad mount "shake" that usually accompanies them. I can hear this noise from both sides of the engine above it and from under the car.... The fresh oil change is already sullied with a fuel smell and has some combustion smell to it.
I think i finally broke it, In my mind the engine is ****. The main question now is what is causing the bucking and intake popping could a damaged piston or broken ring land cause that???
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,946
5,818
213
Feb 22, 2018
#2,282
  • Feb 22, 2018
  • #2,282
That noise doesnt around good. I can't speculate what's wrong from the video.
I Just hope you figure it all out and it doesn't cost a lot to get it back together.
A broken ring land shouldnt cause that. Usually, the car will smoke or lose compression. Seems like it was a timing issue that caused whatever is going on now.
Wish you were closer... I've got a spare 302 that i know is good i'd give you, if it came to that.
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Feb 22, 2018
#2,283
  • Feb 22, 2018
  • #2,283
What were your TPS(s) doing at the moment that started?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 22, 2018
#2,284
  • Feb 22, 2018
  • #2,284
Could you clarify what you mean?. If your taking about the bucking/popping....
The wife was driving the car, normal acceleration in second gear. Tps was around 45-50% making just under 1psi. Fuel here is always a non issue 12.7 AFR, the rpm is bouncing erratically during the bucking on the datalog from 2100 to 2600rpm.
I should also note there is a pressure spike in the manifold when this happens, spike anywhere from 8- 16 psi
MY 85 GT
1,852
208
104
New Jersey
Feb 22, 2018
#2,285
  • Feb 22, 2018
  • #2,285
Is it coming from the valve covers or the bell housing..area? car has a miss? did you do a compression test yet?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 22, 2018
#2,286
  • Feb 22, 2018
  • #2,286
It's coming from all over, car does seem to have an ignition issue I can't pin down, no comp test just found the noise this morning was going to drive it to work.
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Feb 22, 2018
#2,287
  • Feb 22, 2018
  • #2,287
I'm wondering if there is some reference in your tune that is not taking collective TPS into account --or-- this is the spot where throttle resolution is being missed and possibly corresponds to the opening/closing of the secondary throttle body.
12.7 AFR seems rich as eff for 1 psi. Popping helps support that theory.
Every bucking issue I've encountered so far has come down to tuning.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 22, 2018
#2,288
  • Feb 22, 2018
  • #2,288
No this is below the secondary TB opening, I see the tps enrichment in the log no issue there. 12.7 at 1psi is no issue at all it is in fact around the best mbt AFR for a NA car. Usually 12.5-13.1 makes best power near atmosphere pressure.
The bucking has always occurred at this rpm on me in first gear, whatever it is that is happening was less prevalent before yesterday and has gotten worse.
I changed the throttle configuration to try and alleviate the issue thinking it was a pressure surge problem. Obviously it didn't help.
Popping in the intake manifold is usually a lean condition
This isn't your usual bucking that I usually tune out this is very violent like the spark fires on the wrong cylinder
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Feb 22, 2018
#2,289
  • Feb 22, 2018
  • #2,289
Another random thought:
Timing Tip-in
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 22, 2018
#2,290
  • Feb 22, 2018
  • #2,290
Timing Tip-in
Its all based on manifold pressure, when it occured this time the timing was only 24* due to manifold temps being near 200*
I do see that the intake temps went from 200* to 340* after the incident [engine stalled when she held the clutch in] this tells me that there was a fire in the intake manifold.
NOT GOOD
this is why i think there is a timing issue something had to ignite that fuel with the intake valve open over multiple engine cycles
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Feb 22, 2018
#2,291
  • Feb 22, 2018
  • #2,291
by-pass valve?!?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 22, 2018
#2,292
  • Feb 22, 2018
  • #2,292
Noobz347 said:
by-pass valve?!?
I do have a vacuum operated bypass valve that is open under normal conditions to keep intake temps under control.
This engine will see higher intake temps due to the fact that the floor of my manifold gets hot oil slung on it. Average intake temps for this setup are within 10* of coolant temps.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 22, 2018
#2,293
  • Feb 22, 2018
  • #2,293
I think I am going to do the obvious stuff first, compression and leakdown test. If those pass then I will swap the coil packs and double check my wires are not cross firing. They do pass behind the intake manifold and run parallel.
If the engine is knocking after that.... well idk I think my wife will kill me if I try and fix it.
On another note wouldn't a bottom end noise be faster than what was in the video?
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Feb 22, 2018
#2,294
  • Feb 22, 2018
  • #2,294
and doesn't generally disappear coming just off idle.
Bullitt347
I have been doing it wrong this whole time
4,007
2,990
204
Middle of Maine
Feb 22, 2018
#2,295
  • Feb 22, 2018
  • #2,295
Rod/wrist pin issue.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 22, 2018
#2,296
  • Feb 22, 2018
  • #2,296
this was mentioned as well. So how sure are you?
Still does not get down to the root cause of the problem I have been chasing, frustrating as hell
90sickfox
Mar 2, 2015
6,946
5,818
213
Feb 22, 2018
#2,297
  • Feb 22, 2018
  • #2,297
Time to take the oil filter off and cut it open. Cheapest and easiest way to see if something let loose. If something metal is beating itself to death....it'll leave evidence in the filter " 9 times outta 10 ".
She has no say in what you do to fix it.... it happened on her watch. That would be my story anyways ... guess that's why my wife won't drive my project cars.... unless she just thinks I'm a lousy mechanic when I've been drinkin'.
I tried to tell her that's when I do my best work.
Reactions: General karthief
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 22, 2018
#2,298
  • Feb 22, 2018
  • #2,298
Well some new developments. Don't know if it has anything to do with the bucking and popping but....
I ran the car and got the knock when I got home, then removed the belt to help isolate the sound... except there was no longer a knock.
Put belt back on and the knock is back loud as ever, I went and got a piece of wood to use as a makeshift stethoscope. Sure enough I think the blower has begun to eat itself. Goes away with rpm but is loudest at the blower, then sheet metal intake I have on it likely amplified the sound.
While this sucks I at least have a starting point. Still does not explain the backfire though
Reactions: 90sickfox
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Feb 22, 2018
#2,299
  • Feb 22, 2018
  • #2,299
When my KB makes noise at idle, it's almost like tapping the side of a bell.
90sickfox
Mar 2, 2015
6,946
5,818
213
Feb 22, 2018
#2,300
  • Feb 22, 2018
  • #2,300
That's better than a new engine. Explains alot. The backfire tried to back spin the blower....so everytime the backfire occured it blew up in the intake.....causing pressure to rise....that pressure rattled the blower.
Smh..... guess it's better than an engine. Depending on what exactly it is.... that thing can be rebuilt and ported.
  • 113
  • 114
  • 115
  • 116
  • 117
  • 239
T
TJ's Eaton M90 Build-Up Thread
  • tjh566
  • Jan 8, 2007
  • 1994 - 1995 Specific Tech
  • 3 4 5
30K
1994 - 1995 Specific Tech Oct 15, 2007
RAD
R
