The only side effect that you, me, and Collin are having as a result of a contaminated oil galley that is finally cleaning itself up with oil and filter changes, is this:
All of that residual sht that keeps ending up in the drain pan and filter is also embedded in the bearings.
Whether or not that will shorten the potential life of these engines will be a wait and see.
I don't remember if you showed us what your old bearings looked like that came out of the engine, but a bearing failure is not typically cured with just a bearing replacement. To get rid of the residue, you would've had to do a full tear down, and flush that oil galley. What you are seeing is probably what was there the minute you set that crank back in the block.
so what can i do... until this is done i cannot begin work on the engine again. I understand i mean i did have to tear it down twice already..... this is out of my control this time.
