Be careful when you start spacing sht.You will create bumpsteer if you space the sway bar mounts too differently from their normal intersect points with relation to the swing arc of the control arm.The k member bolts are metric.
I just went out and looked at everything, I see no reason why the bolts wont be long enough to reuse with a 3/8 spacer.
The swaybar is going to smash the pan for sure, so if I space the k member I will need to space the swaybar mount easily twice as much. Maybe even an inch.
Not a big deal easy enough to work out.
