equal length shorty headers
5.0_sleeper
47
Hello, me again. Got another question for you guys. I am looking into a set of headers for my 88 gt, but I am confused on a few things. Was wonder about the equal length shorty headers that the big name brands sell, do they actually flow better or are they for just looks. Also was wondering if there is any problems with hand clearance in between them, or plug/boot clearance with these. Also if there is any problems with these headers on any cylinder heads out there(older 351's or world heads) or any in perticular.
thanks 5.0_sleeper
I personally would go with a set of longtubes if you're looking at headers, then again if you want any emissions compatability you're stuck with shortys, equal length may give you a little more power, but they are a major pain in the ass as far as doing a tuneup with getting to the plugs
From what Ive read equal length headers will give you more low to mid power but unequals will give you more power on the top end. Equal length headers are notorious for installation problems, little to none access to the spark plugs, and burned up spark plug wires, so I'm in favor of unequals. AS far being compatible with any heads....it depends I defiantly know they will not fit a 351 , and they will also not fit gt40p heads. Most manufactures make heads for all applications. Most manufacturers also advertise a gain of 8-10 hp with unequals and 8-12 with equals, so in my opinion the hassle of equals are not worth the potential 2 hp gain.
i had a set of flowtech equal shorts. i never had any problems really getting the plugs. BUT i did have problems melting clutch cables when i did my t5 swap. i ended up buying BBK unequals and it was PITA getting the equal flowtechs out. but the bbks slid right in. but i have seen bbk equals in person and they have a different routing that the flowtechs and didnt take up as much space. so they would be better
i'd just get the unequals, make it easier. i doubt you would be able to distinguish a difference if u swapped b/w the two
I had mac equals an liked them...only prob was the pass side sat right on the frame an was close to the a/c line. they were a little harder to get the bolts started in a few spots, but it seemed like it had more torqe down low in the rpm band..i changed to jba cuz the macs didnt seal well with the ind flanges
I've had both equal and unequal shorty's, and I will never buy another set of equal's. They're just not worth the hassle. I had trouble with burning plug boots, and if you still have your smog equipment, it will interfere too (the rubber hoses).
Just get the unequals, I've always been happy with them.
Jeff
Ok, that part is settled. Unequal's it is, now for the second part. Why won't the headers fit 351, or even world heads. I have been thinking about puting a set of either roush 200 or windsor sr. or finding a set of older 351 heads and having these redone. Either way if these won't fit then what shorty will.
The problem with the 351w is with getting the headers to mount to the mid pipe AND not hit the trans tunnel.
The 351w is about an inch taller than a 302.
The bolt pattern on the 302 and 351w heads is exactly the same. Actually the casting between these 2 heads is virtually identical in most applications.
jason
what I am thinking about doing is going the budget method and getting a set of 351 windsor heads for my 5.0,not swapping motors. the guy I work with, says the shorty's will work on both, the only difference is the 351 exhaust ports is a tad bigger than the 302.
Like jrichker said, the headers will bolt up to either 302 or 351 heads. I beleive the reason people say the unequals won't fit a 351 is because the 351 is wider (taller deck = wider engine), and the unequal shorties may run into stuff. It has nothing to do with not bolting to the heads.
I'm not sure if stock 351 heads have any advantages over your stock E7's. I'm sure some guys here can tell you the exact differences, valve size, combustion chamber size, runner volume, etc. Just make sure the 351 heads really are an upgrade before you go to the work of installing them.
Jeff
That will work just fine.
The 351w and 302 castings are basically the same.
The 351w heads use a larger head bolt though. You will need a sleeve/bushing, IIRC.
jason
