error codes.
MikeROD16
Miami, FL
ok i got error codes 21 22 34 42 92
they all have to do with vacuum and running rich acording to the little booklet my scanner comes with. but what do you think it could exactly be??? Im not sure if i have to replace everything or just one thing that effects all the others. Help!!! thnx in advance! :nice:
They're not all vacuum related codes.
The ECT can affect A/F ratio and the EGR code can affect drivability.
Not knowing what your car is doing or if any of the OEM systems are deleted makes it tough to say more.
Good luck.
Did you clear codes after replacing the ECT?
OTherwise, new does not mean good, nor does it rule out a wiring issue. For instance if the Ref and Sig short together, that causes issues.
Go to JRichker's idle surge sticky and check the calibration of your ECT at room temp and at operating temp (180*F ish).
You still didnt note what the car is doing so no one knows if the EGR code matters.
Good luck.
21 could be caused by running the KOEO with coolant temp below 50°F, or the KOER with coolant temp below 170°F.
22, 42 & 92 could be related, namely 42 & 92 been caused by 22 (MAP/BP circuit)..... if your '87 is still speed density, make sure the MAP vacuum hose is not leaking, disconnected or broken. If your '87 is a MAF conversion, make sure the MAP/BP sensor is not connected to a vacuum source.... it should be open and reading atmospheric pressure, not vacuum.
34 is a problem with the EGR sensor reading (34 - EGR Valve Position Voltage Above Closed Limit (O,R)).... which could be causing codes 22, 42 and 92...... if the EGR valve is connected to a vacuum line that has vacuum engine idling. To test for this possibility, disconnect the vacuum line at the EGR valve, plug the line, and rerun the KOER self test.
LUK
