Rebuilding my '69 351w from the parts listed below. Please let me know what you guys think this engine will make in terms of HP and torque at the flywheel. I appreciate everyones help on my past posts to put these parts together. If anyone sees areas that need improvement or overkill, please let me know. Thanks.
'69 351w block bored .030 over
stock stroked crankshaft (3.50 inches)
AFR 185 Cylinder Heads
Speed Pro Forged .030 pistons 9.5:1 compression
Scat 4340 Forged Steel H-Beam Rods
Edelbrock Performer RPM (Ports matched to heads)
Street Demon 750 (mechanical secondaries)
140 gph Electric Fuel Pump
Shaker Ram Air (aftermarket 100% ambient air)
Melling standard volume oil pump
1 5/8 Hedman Ceramic coated shorty headers (1 3/4 ????)
Electric Fan (don't know which one I will use)
March under-drive pulley set
MSD Pro Billet Distributor
CompCams camshaft 35-000-8RF (roller retrofit)
duration @ .050" = 224/232
valve lift w/ 1.6 rocker = .555/.565
Lobe sep. angle = 110
(I need to find out valve overlap???)
