stangGT97
svttech76 said:WOW nice way to make friends on here... BTW that suggestion of your was posted already in this thread.
I was just thinking that. Sequence of events:
1low03gt said:My Mac H pipe did the same,i took the stock studs out as it was bottoming out on the stops of the studs,then i put bolts instead,solved the issue.![]()
Superhereaux said:the problem is the stock studs. they have a 'shoulder' on them that prevents a tight seal. buy the stud kit or use a nut and bolt
1low03gt said:That would work if there wasn't a shoulder on the stud,which is the main reason for the exhaust leak issue.
Then, the "shut up everyone here is dumb" comment and
fastangboi said:Whats going on is there are dowels on the header that prevent over tightening, but they are too tall for some aftermarket companies to make a good seal.
Your idea was fully developed prior to you entering the thread, but for some reason its not credible unless you say it. You may have sound advice but we all know now that you don't take the time to read these threads and see what people have to contribute.
