I was going to adjust my lifters hot. Put the clips on and started the engine. Heard an exhaust leak. Found on both heads the exhaust will come out of the lower valver cover bolt holes when the bolts are removed. these are Trick Flow high port iron heads. Everything else seems fine. Should I be concerned?
