Exhaust Gauge Gas Temps?
Snakebite93
114
Frederick, MD
For those who have an exhaust gauge, where do you have the probe mounted? I have mine mounted into the header. When cruising at 60 my temp is at 1100 - 1200 degrees. I currently have 2 high flow cats on the exhaust which lowered the temp dramatically from stock. I only tried high flow cats and the stock exhaust for emissions. I'm thinking if I switch to the H I can lower the exhaust temps. I am running a 331 supercharged with an aod. I think these temps are high... Are they? If so, Any other ideas other than freeing up the exhaust?
Thanks!
EGT probe should be installed within 3"-6" from the cylinder head header flange. Your temps are not high if the probe is installed per my measurements.
I have mine about 11/2" from the header flange. The farther you mount it from the flange, the lower the readings you'll get. Those temps you're seeing aren't high. Cruise light throttle temps seem to creep up more. Mine is usually at least 1400 cruising. Sometimes it'll creep up to 1500. There are other factors that determine your exhaust temp other than fuel mixture. Timing also plays a really big role and can throw you off tuning air/fuel when in fact it's the timing. Retarded timing will give you high temps because a bigger part of the fuel mixture is still burning in the exhaust port rather than the cylinder.
