  • 1994 - 1995 Specific Tech
Exhaust Tips?!
  • Thread starter Thread starter zZsKyZz
  • Start date Start date Feb 24, 2006
Z
zZsKyZz
503
Feb 24, 2006
  • Feb 24, 2006
I have a set of 18" long exhaust tips by magnaflow. 2 1/4" in and 3" out. My question is how did you guys install them? Weld? Solder? Drill? I'm just thinking it'd look stupid if you can see the existing 2 1/4" pipe through the tips.
xkuntrycowboyx
281
Marion, Indiana
Feb 24, 2006
  • Feb 24, 2006
y would you see it in the pipe... you mean slide it all the way over?
if exhisting 2.25 go all the way out the back, you should mach up the tips under or beside exhisting and cut the old 2.25 back to there.. then get a or use that hanger and weld ur tips to the hanger then to the 2.25 pipe.
94MustangGT5.0
288
Champaign, Illinois
Feb 25, 2006
  • Feb 25, 2006
Yeah man, just measure back maybe 17" or so and make a cut. That will leave you enough to weld the new tips to, and you can adjust the angle, length, etc. I used a cutting wheel and removed the hangers from my stock tips and welded them to the new ones.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
