Exhaust Tips?!
zZsKyZz
503
I have a set of 18" long exhaust tips by magnaflow. 2 1/4" in and 3" out. My question is how did you guys install them? Weld? Solder? Drill? I'm just thinking it'd look stupid if you can see the existing 2 1/4" pipe through the tips.
y would you see it in the pipe... you mean slide it all the way over?
if exhisting 2.25 go all the way out the back, you should mach up the tips under or beside exhisting and cut the old 2.25 back to there.. then get a or use that hanger and weld ur tips to the hanger then to the 2.25 pipe.
