Its Friday night and I just went out to my garage and started up my mustang so I could pin point where the a/c drip leak was occuring. Because I wanted to fix it so that I wouldnt run the rish of damaging my passenger side header. So I started the car and ran the a/c for a while and when I shut it off- my shop light slid under my car so I went down on the ground to get it and I noticed a black mark by the weld on the passenger side pipe before the muffler. I then noticed water dripping out of where the black mark is. Now I know when you run the a/c and-or heat water drips out the end of the pipes as ive heard that they do on most fords, but to cause a hose in the weld before the muffler?? I don't know whats happening- or what could be causing this??
Was the weld weak? Is there water in my engine? Is something backed up?
ALSO SHOULD I PATCH THE HOLE??
Any ideas and help would be greatly appreciated!!
I have no idea if this has anything to do with whats going on, but my cooliant is near the low mark in the tank. I use synthetic oil. I also use fuel & carb cleaner every 2nd time I fill up.
Thanks.
My name is Craig, I am 25, I live In Amherst NH, 03031. I own a 2002 Mustang Convertible v6, 4 spd automatic, 35,000 miles. I keep the car cherryed inside and out. I am also extreamly diligant when it comes to daily, weekly and monthly maintnance.
Very little mods- 90% stock- except: True duals with ss series mufflers. ss tips. 4.10 gears. k&n fliter with custom factory cut air box.
Thanks.
