Exhuast: All at once, or piece by piece?
CManT1914
3,172
Killeen, Texas
I'm about to do some exhaust work to my car. Would it be better to do everything at once (i.e. header, h-pipe, cat-back), or do one thing at a time? If I were to start with a cat-back, would doing an h-pipe and headers down the road be harder, or more expensive? I'm going to have a shop put this stuff on. So basically, would it be cheaper and less of a hassle to do it all at once, or just spread it out? Thanks
The Flowmasters are going to need welded, but the H will bolt to the headers and usually the catback/mufflers bolt to the H but i've seen a rare few that dont. You'll have to weld the tail pipes to the mufflers at least.
This is one reason (aside from being relatively cheap) that i buy MAC. They're not the best you can put on your car but they sound sick and they're 100% bolt on parts, which is great since i dont have a welder.
Does Mac make headers too? Because I LOVE doing my own work, but I can't weld. So if I could get an entire exhaust that was bolt-on, that'd be great.
I did mine one at a time (funds were limited) but I wanted to do it right the first time, I went all stainless, I bought the bassani X first, then the magnaflow cat-back, and recently I finished with FRPP ceramic coated headers, no welding required with this set up, in total it took me 6hrs to do the whole thing on the floor in my garage on ramps. Like you I get more out of doing it myself, plus with the money you save you can get something else.
They make everything from unequal length shorty headers to full length headers, midpipes and exhaust systems.
Definetly go MAC if you want bolt-together and save money with a cheaper and yet good cat-back. I want a mac cat-back, and am getting one soon (damn weld in flows YOU SUCK, found out they were weld ins) and the only problem my cousin has with them is if you don't keep the tips clean, they will rust. But I'm sure you wash your car a lot, and if you keep them tips clean, no worries. :) Oh ya, definetly go all at once if you can, but piece by piece isn't too bad. A midpipe and cat-back would be a good start at least. Good luck to ya, :D.
