Back to square ONE
I almost hate to post this, but I'm defeated and I've got several questions to answer, so apart the motor comes. Thanks all for the input; this is where this thread will end until I tear it down. But I want to address a lot of the input everyone gave me: After adjusting the pre-load for the umpteenth time, I decided that I would run the motor and adjust them on the fly. I took a set of the old Bronco tall valve covers, cut one open and folded back a flap of steel so I could get a socket on the rocker nuts. Wow.... the upper clatter was almost completely gone! About 2 minutes into this wonderful idle, clack, clack, clack, one of the roller rockers turned a bit sideways and bent a pushrod.....damn. I truly believe that I wiped out a lobe (or two) early in the process and I've been attempting to chase a botched-up (by me) cam. The crankcase oil is extremely dirty.... with a nice silvery content, which tells me I gots plenty of cam lobe floating around. So, I'm plulling this baby apart.... an expensive lesson, but I've learned a ton. Funny, the stock rocker covers do not show ANY contact from the rockers, but thinking back, I would tighten the adjusters and the noise would get better, but then the idle would suck....back off, and the noise would get worse, but the car would idle pretty good. Lesson: early 289 valve covers don't work with Magnum Roller rockers on standard 3/8" studs.... I went and bought the Edelbrock tall alum covers for the next round. OK, what's my next street cam with stock heads, Performer intake, and Tri-Y headers? Thank you all. Member "66forFun" gets the prize for the valve cover suggestion!
