Concept: the combustion process always takes the same amount of time, no matter what RPM you are turning.
Some further explanation will help. Keep in mind that the numbers are for educational purposes only.
Since the combustion process is supposed to be complete before the piston gets too much past Top Dead Center (TDC), the faster the engine turns, the sooner the combustion process must start. This means the ignition system must fire sooner at 3000 RPM than it does at 1000 RPM for maximum efficiency. Hence, the requirement for spark advance.
Total timing is usually around 34-38 degrees at 3500-4000 RPM. The computer's internal tables have the spark advance data in them based on RPM, load, air temp water temp, throttle position and other factors. The computer has 22-30 degrees of advance in its program. Use 14 degrees base timing and the computer adds spark advance to come up with a total timing figure. . At WOT, the 14 degree base timing gets added to the computer's WOT timing figure of 24 degrees for a total of 38 degrees.
