Mr. Rustypwnz
Advanced Member
you have to get the stock unit off the old block and swap them, so the ole' fl1a will screw on.
oh yes it is, I believe that it is a hex pattern inside the hole on the stang unit, get the breaker bar on it, and just try and budge it, because they break easilly!! get a set of huge visegrips and and crank down on the exploder unit, and back it out, then put the fox unit in tighten it down and your golden, I didnt notice this until I went to fire my engine!! that will piss ya off in a hurry!!
oh yeah, you can use the tfs cam with these heads, you 'might' want to swap springs because they are good to .500 and the tfs cam gets to .510....
that was not removeable?
