Explorer 8.8--what years?
  • Thread starter Thread starter CarFreakGT
  • Start date Start date Apr 4, 2009
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Apr 4, 2009
  • Apr 4, 2009
I did a search on the Explorer 8.8 swap for my 68 coupe, and have a quick question: I didn't see in any of the threads if there are certain years that I will be limited to in my search. Can anyone fill me in?
I've found a local yard that has some pretty good prices, and they currently have multiple Explorers ranging from 1991-1999 available. I haven't been to this one yet, but my friend tells me that it's incredibly well-organized and user-friendly.
Also, would any particular models be preferable? Any way to determine gear ratio on-site?
Any other tips, thoughts are appreciated! Thanks in advance for any input!
EDIT: My goal in considering this swap is to get a reliable rear and disc brakes if I can. The current rear is in need of quite a bit of work, and I thought that now may be the time to consider this swap. The ultimate goal of the car is a hard road driver (not daily driver, though) w/ < 400 hp.
nitroracer
Nottingham, Pa
Apr 4, 2009
  • Apr 4, 2009
All first and second generation explorers have 8.8 rear axles with an offset center section. The earlier, boxy explorers 91-94 have narrower axles (57ish) and drum brakes. The later 95-01 trucks have a wider axle (look at jeeps for the width, they love to convert to them) and disc brakes. Either style usually has gears ranging from 3.27 to 4.10. The door tag will have a section for 'AX' and a code underneath I believe all ford from the 80s on up use the same codes to determine the gear ratio.
mrmustangman357
763
Apr 5, 2009
  • Apr 5, 2009
96-up have discs. the bottom left hand of the axle tab says the gearing, it will have an L for a lim. slip
ex: 3L55. 3:55 gearset with trac lok.
D
D.Hearne
11,730
south louisiana
Apr 5, 2009
  • Apr 5, 2009
There were also 3.08 geared 8.8's too. The 3.73's come in both brake styles. The 4.10 geared are the hardest to find. Or at least that was the case at the yard I looked in. Most were 3.08 or 3.73.
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Apr 5, 2009
  • Apr 5, 2009
Thanks, guys! Good info in all 3 of those posts--much appreciated!
9
96 DOHC Cobra
542
Cerritos, CA
Apr 5, 2009
  • Apr 5, 2009
All Explorers up to 2001 had solid axles. 91-94 had drum rears. 95-01 had discs. These are also all the same width. The disc brake rears "may" be a 1/4" to 1/2" wider due to thicker material of the rotor center. Other than that, they're all the same width. The axles are interchageable through all these years. Like others have already stated, check the metal tag on the center section to find the ratio and look for the "L" in the midlle of it to confirm it has a traction lok. They came in all ratios from 3.08 to 4.10, but 99% of the ones I find around here have 3.73s and traction lok.
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Apr 6, 2009
  • Apr 6, 2009
Thanks, Cobra. I would be VERY excited to find that. That combo--3.73 w/ traction-lok--would be my preference!
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
R
8.8 rear end for '67 coupe, shortened - next steps
  • rubendenver
  • Dec 15, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jan 8, 2025
GOvert
G
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
