explorer accessories
  • Thread starter Thread starter stykthyn
  • Start date Start date Apr 22, 2008
stykthyn
5,232
2,652
223
gainesville
Apr 22, 2008
  • Apr 22, 2008
I am running just an alternator and PS pump. can I use the explorer brackets and accessories??
enyawix
507
Apr 22, 2008
  • Apr 22, 2008
I would not use the alternator as it is a POS. I would use the timing cover, water pump, and harmonic balancer / trigger wheel.
stykthyn
5,232
2,652
223
gainesville
Apr 23, 2008
  • Apr 23, 2008
I have a fox timing cover and harmonic balancer already.I just need to know if I can use the old explorer brackets to mount the alternator and power steering pump.
5.0ina66
664
Ohio
Apr 23, 2008
  • Apr 23, 2008
How so? it's a 130 amp 3g, just like all the other newer fords. The mounting setup on it is weird as hell, sure, but I can't begin to fathom what would make it a POS?
samickguy15
404
Delavan, IL
Apr 23, 2008
  • Apr 23, 2008
Same here...The Explorer, at least the one I got 99 & 01 both use a small pump with external reservoir which is mounted up higher. Alternator runs $130 new IIRC...I thought about running explorer accessories, but I already have the 5.0 stuff...havent decided yet...
enyawix
507
Apr 23, 2008
  • Apr 23, 2008
I like that it is a 130 amp 3g. how it mounts close makes extra room for a big radiator, but No one sells the mounts.
samickguy15
404
Delavan, IL
Apr 23, 2008
  • Apr 23, 2008
You just have to get factory accessories. My motor came with brackets, but no A/C or P/S pump or alternator.
stykthyn
5,232
2,652
223
gainesville
Apr 23, 2008
  • Apr 23, 2008
factory fox acessories or factory explorer accessories?
enyawix
507
Apr 24, 2008
  • Apr 24, 2008
factory fox accessories stick out more from the engine
stykthyn
5,232
2,652
223
gainesville
Apr 24, 2008
#10
  • Apr 24, 2008
  • #10
cool, I still have those laying around. thanks guys
one other question. would a fox smog pump delete and ac delete kit work on the explorer brackets??
5.0ina66
664
Ohio
Apr 24, 2008
#11
  • Apr 24, 2008
  • #11
I've got a full set of exploder accessories and bracket and everything, with a new (or new-ish) alternator, if anyone would happen to be interested, PM me.
samickguy15
404
Delavan, IL
Apr 24, 2008
#12
  • Apr 24, 2008
  • #12
Uh...No. Just run a smaller belt.
stykthyn
5,232
2,652
223
gainesville
Apr 24, 2008
#13
  • Apr 24, 2008
  • #13
why cant I think of stuff like that
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Engine Brackets for Gt40 heads with ac and ps?
  • Xavierg208
  • Nov 14, 2025
Fox 5.0 Mustang Tech Nov 16, 2025
limp
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
G
Engine PATS off pcm for 1999 Explorer 5.0 swap
  • GOvert
  • Dec 23, 2025
Fox 5.0 Mustang Tech Jun 14, 2026
GOvert
G
  • Mindseye007
  • Aug 16, 2026
Mindseye007
