Finally got my Explorer intake installed and running. It runs strong. I am fairly pleased with the swap, but ... it seems to be missing something.
I have the standard BBK CAI, Pulleys, Off road H-pipe, Flowmaster Force II's, Recent tune-up, 65mm FMS TB, FMS 3.55's, STOCK MAF, STOCK Injectors, STOCK fuel pump and Regulator, STOCK heads, STOCK headers, STOCK chip ... I ported and gasket matched the explorer upper and lower - a lot! Its a smooth clean job and the adapter is a Trick Flow 75mm. I ported the opening of the Explorer to 75mm to match, and I beveled the rear of the 65mm TB to open up to a 75mm.
Did I make this thing TOO free flowing for my set-up? I am trying to keep this thing in the budget daily driver class - so I am not considering heads or a cam even. Am I creating a lean condition? Would a larger fuel pump and Adj. fuel pressure regulator, larger injectors, and larger MAF fix it? Are the stock headers choking it? It just seems to have a lot of potential, but something's missing! Also ... I know I re-installed the distributor correctly, but does the timing get re-set after being unplugged for a couple days? I was running around 11* before the swap. I don't have a timing light to check it - so if it does - let me know. I only drove the thing for about 5-10 minutes so far ... does it take longer for the computer to re-learn the manifold?
Sorry for all the questions ... just seems no one around me has a clue that this swap even existed. HA! Am I missing something stupid? All the hoses are hooked up and correct. Help me out!!
