Explorer Intake Swap
JD1964
there is enough sticking out to grab on to
3,463
1,550
194
Maryland
I previously saw a thread or link in this forum to tech info and tips on swapping explorer intake for the factory one on Fox Body. I looked but cant find it. Can anyone please post links or info regarding the swap?
Thanks in advance.
John, it's been done a thousand times so there is plenty of info out there. Couple of things.
If you want to retain the fatory EGR get a 96 and older intake with the EGR passages. It will also have the IAT sensor pad on the #5 runner. If you plan on keeping the EGR tubes and heater core hoses, use the metal heater tubes from the explorer or you will need to tap the passenger rear pad on the explorer intake for the mustang hose. I can't remenber the PN off the top of my head, but I used the Felpro steel core intake set with the blue rubber end pieces, and the seperate Explorer upper to lower intake Felpro gasket. The explorer upper is a 65MM opening which I used the gasket and opened up to 70mm. All of your mustang parts- injectors, rails, FPR, bolt right up. Expect maybe a 10-15hp bump from the intake and another 40-50 if you put on the explorer heads- which I strongly suggest you do at the same time.
Mildly ported Explorer heads are going on at the same time along with new TFS valve springs and 1.7 Ford Racing roller rockers (stock cam).
The Explorer intake I have has the IAT on #5. I did not get heater tubes from the Explorer but my Mustang ones will bolt right up because it just has one bracket as part of the tube assembly. One of the intake bolts has a stud on top and the bracket just bolts up there.
The vacuum connections are a tad different beneath the upper. The Mustang intake has two small ports on the back and the Explorer only has one. Although the Explorer has extra ports further towards the front. I'll probably just extend one of the vacuum lines to the forward location.
Here are two pics comparing the stock Mustang parts and the Explorer parts.
In the first pic you can see the heater tube assembly still attached to the stock Mustang intake. You can see how it will bolt right up in the swap process.
I the second pic, you can see the difference in the vacuum line ports on the underside of the upper manifolds.
Everything you could ever want to know about Explorer/GT40 intake manifolds: http://forums.stangnet.com/showthread.php?t=551505
Explorer intake swap.
I got mine off a 96 Mountaineer with the 19# injectors and 65 MM throttle body for $250.
The ACT (Air Charge Temp) sensor will probably need to be moved. The GT 40 lower manifold isn't drilled & tapped for it to go into the intake like the stock manifold was. There is a boss cast into the GT 40, but a machine shop will have to drill & tap the new manifold. The best spot for the ACT is the air box if you don't do the drill and tap thing. You get to cut and splice the 2 ACT wires in order to make them long enough to reach the air box. Solder the wire extensions on the existing wires & use heat shrink tubing to cover the splices. Offset the place where you cut the wires so that you don't have a big bulge when you put heat shrink over the 2 wires to cover & protect them. The air box gets a hole (5/8" or so) for the ACT drilled about 1 1/4" down & 1/1/4" in on the front top side near the upper radiator hose. A brass fitting nut from Home Depot or Ace Hardware secures the ACT into the air box.
If you are very clever, you will find that the ACT connector comes apart so that you can remove the pins. A very small screwdriver releases the lock in the front of the center insert, while another small screwdriver inserted in the back pushes it out. Once the center insert is out of the connector shell, the pins come out easily. New pins are available from AutoZone in a $5 electrical pin kit for Fords. Crimping the pins on the extender wires saves you from having to splice them twice: once to put the connector on and once to extend the wires.
6 ft black 18 gauge wire
6 ft green 18 gauge wire
6 ft 1/4" heat shrink tubing
1 ft 3/16" heat shrink tubing
Measure the 2 extender wires & cut them to length, crimp one set of pins on them. Then mate up the extender pins with the wiring harness & slide the 3/16" heat shrink tubing over them & shrink the tubing. Then slide the 1/4" heat shrink tubing over the pair of wires and shrink the tubing. When you are done you'll have about 1" of wire left without heat shrink tubing on it to strip & crimp the new pins on. Stick the new pins in the old connector shell, assemble it and you are done. It looks as good as factory. Some wire loom can be used to enhance the "Factory Look".
Use the TPS and IAB from your old throttle body. All the EGR passages were there and fit OK. Use you old fuel rails and regulator. You will probably need a new EGR spacer adapter and gaskets. Without the EGR spacer, there is no place to mount the throttle linkage support bracket.
I used the stock water lines on the Explorer manifold and they connected up to the EGR without any problems. I made a “U” out of ½” copper pipe and sweat soldered it together. Then I used it and some hose with clamps to bypass the leaky heater.
The vacuum lines you need are 1 small line for fuel pressure regulator, 1 small line for A/C,1 small line for EGR and another small line for the smog pump. One big line at the back goes to the vacuum tree for the power brake & A/C, one big line goes to the PVC valve. The other big line goes out the front for the carbon canister. In a pinch, one of the small lines can connect to the spare port on the vacuum tree. Cap or plug the remaining lines since they aren't needed.
The stock Explorer linkage didn't come anywhere near fitting, so I made an adapter plate for the throttle linkage so I could use the 65 MM throttle body.
This is what I did:
Make a drawing of the position of the old throttle body linkage arm and its angular position relative to the centerline of the throttle body. Remove the ball stud off the explorer TB to make way for the adapter plate. Drill and tap a 10-32 hole in the linkage parallel to the TB shaft. Make an angle bracket out of 1" angle iron 3/8", drill a 3/16” hole in the center of each one of the legs. Then bolt it on where the hole was drilled & tapped. Then make a circular adapter plate out of 1/4" thick aluminum to bolt the two linkage arms together. Then bolt the aluminum plate to the existing linkage, and the angle bracket. Next mount the arm with the ball stud off the old throttle body on the adapter plate using the drawing to get the angle correct. You will need an aircraft type countersink for one of the bolts that secures the plate to the explorer linkage arm. It ends up being under the arm with the ball stud for the linkage. It works great and looks neat.
The Explorer TB could have been real simple if I had a gas welding torch or taken the TB to a welding shop. Just grind the mushroomed part of the TB shafts so that you can pry the linkage arms off. Then swap the stock arm onto the Explorer TB and braze it onto the shaft. It Takes about 3 minutes or less worth of work with the torch, so it shouldn't cost much.
I didn't have access to a welder, so I fabb'ed the plate in my shop. I took about 1.5 hours to do it, it was a measure, cut, and fit type of operation.
Also see http://www.veryuseful.com/mustang/tech/engine/ConvertingExplorer65mmTB.pdf for modifications to adapt the 65 MM Explorer TB to a Mustang
Vacuum line connections:
One large vacuum line from the upper front goes to the carbon canister
One large vacuum line from the rear goes to the vacuum tree.
One small line in the front feeds the Smog pump solenoid control valves on the rear of the passenger side wheel well..
One small line in the rear goes to the fuel pressure regulator.
One small line in the rear goes to the EGR suction regulator.
One large line in the rear goes to the PVC valve.
Diagram courtesy of Tmoss & Stang&2birds - Typical Vacuum Routing for a Fox stang 5.0:
Diagram courtesy of Tmoss & Stang&2birds - Intake manifold bolt tightening sequence for a 5.0 Fox stang:
Intake manifold to head bolts
--Step 1 96 in/lbs
--Step 2 16ft/lbs
--Step 3 23-25 ft/lbs
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Here's some tips...
Tools: a good torque wrench is a must have item. A razor blade scraper that holds a single edge razor blade from Home Depot or Ace hardware is another handy thing. Get a Chilton or Haynes shop manual - you'll need it for the bolt torques and patterns. The intake manifold has an especially odd pattern. You'll need access to a timing light to set the timing after you re-stab the distributor. Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling. Put some motor oil on them when you put the line back together.
The A/C Compressor comes off with lines still connected. Mark all the electrical, smog and vacuum lines with tags to help you remember where to re-connect them. If you have a digital camera, take several pictures.
Whatever you do, don't skimp on cleaning the gasket surfaces. New gaskets need to seat against bare metal and not the residue left from the old gaskets in order to seal leak free. This is the most time consuming and tiresome part of the job. Put some cardboard in the lifter valley to help catch the gasket scrapings. Have a shop vacuum handy to suck up the scrapings and any coolant that leaked into the lifter valley.
Look for little things that need to be replaced like the short hose from the thermostat hosing to the water pump, damaged vacuum lines and hose clamps that are rusted or broken.
Plan on cutting the thermostat to water pump hose, or removing the thermostat housing. Also plan on removing the distributor to get clearance to remove the intake manifold. Remove #1 spark plug, stick your finger in the spark plug hole and crank. When your finger gets air moving past it, stop cranking. Turn the engine until the timing marks line up with the pointer. Now you can pull the distributor out. Be sure to put a rag or cap in the block where you removed the distributor. It will save you trouble if something falls into the empty distributor hole.
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface. Also use the weather strip adhesive on the side of the gasket that mates to the head. When you are done, the head surface and the gasket surface that mate together will have weather strip adhesive on them. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with lots of Blue Silicone gasket sealer and put it together. TADA! no leaks, and no gaskets that shifted out of place.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $3-$4 per kit. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber. Heat the pintle caps in boiling water to soften them to make them easier to install.
Plan on doing an oil change within 2 hours of run time on the engine. This will get the debris and coolant out of the oil pan.
Consumable items:
Upper manifold gasket
Fel Pro 1250 or equal lower manifold gasket set.
Short formed hose between thermostat hosing and intake manifold
6 ft 7/64" or 1/8" vacuum hose
2 ft 1/2" heater hose
1 1/2 ft 5/8" heater hose
Blue Silicone sealer
ARP antiseize or equal for the bolts
4 each 3/4" hose clamps (spare item in case the old ones are bad)
4 each 1/2" hose clamps (spare item)
What can happen if you don’t use the stay in place gasket…
Ask Nicoleb3x3 about the intake gasket that slipped out of place and caused idle and vacuum leak problems that could not be seen or found by external examination. Spay everything with anything you have, and you won't find the leak...
photodisplay.php
Want to wear yourself out with info on the Explorer intake manifolds? See http://www.stangnet.com/mustang-for...d-gt-40-intake-thread-56k-dont-bother.551505/
jrichker,
Whats your opinion in moving the ACT to the airbox as a performance mod? Or is it better in the intake?
On second thought, scratch that question. After reading the following, I'll put the ACT in the intake where it was designed to be.
How will the Fox computer react to the ACT being moved from the lower intake to the Intake Airbox?
Thumbing through the TwEECer (CalEdit) this is what can be seen...
In the X3Z Calibration
FN 825B - ACT will increase the engine idle rpm after about 192F, maxing out at 64rpm by 208F
FN 220 - EGR Multiplier is 0 until 58F, maxes out at 1 by 60F
FN 126 - Spark advance starts to retard at 160F maxing out at -2* by 190F
FN 135 - WOT spark advance is retarded starting at 150F, maxing out at -6* by 240F
FN 300 - Open Loop Fuel Multiplier is unaffected by ACT (always 1)
SCALAR - ACT MUST be between 100Fand 200Ffor the Adaptive Strategy to start learning
In the A9L Calibration
FN 825B - ACT will increase the engine rpm by 48rpm at 200F, and a max of 72rpm at 226F
EGR Multiplier is .8 until 0F, then rises to a max of 1 by 56F
FN 126 - Spark advance starts to retard at 160F maxing out at -2* at 190F
FN 300 - Open Loop Fuel Multiplier is .64 until -40F, .81 by 0F, and maxes out at 1 by 76F
So what does this mean?
Idle speed – Obviously for both calibrations the affect is going to be minimal, assuming all other idle contributors are working properly. Moving the ACT to a cooler location should not have a major impact on idle speed.
EGR – Moving the ACT to a cooler location will affect the function of the EGR. It would not be recommended to try and pass an emissions test with the ACT in the airboxon a cold day (below 60F).
Spark – The Spark Advance is RETARDED with higher temps. Moving the ACT to the airboxcan help to keep ignition timing higher. However, keep in mind that Ford used the ACT as a ‘Safety Factor’ for preventing high temp detonation. False information to the EEC-IV will make detonation more likely when the engine is warm/hot.
Fuel Multiplier – The Fuel Multiplier increases with higher ACT temps. Due to the low temps at which the ACT will impact the Fuel Multiplier this is not likely to cause an issue.
Adaptive Strategy – This may be the most critical one for most daily driver Mustangs. Not allowing the Adaptive Controlto function (because the ACT never sees 100Fin the airbox), could hurt fuel economy and could cause drivability issues.
I haven't messed up anything yet. As you can see, I try not to remove things if I don't have to. I know what you're thinking. "What, you didn't take the headers or distributor off?" Nope. I know I may need to take them off for a smooth unobstructed installation. I'll do a few dry runs without gaskets to see whether I should remove the headers and dist before reassembly.
As far a fuel delivery goes the car was running fine with no obvious fuel related problems when I took it apart.
As far as the fuel injectors are concerned, should I be looking into having them professionally cleaned before putting them back in just for added measure? In normal use, I had already been running Chevron Techron fuel injector cleaner in a full gas tank periodically.
They are stock 19lb. I have a new O-ring kit for the re-install.
Is it possible that this intake gasket was interfering with the injector spray or is this amount of overhang typical and not a problem?
Preparing the 65mm Explorer TB for the swap. I hacked out the crankcase breather tube from a donor Mustang TB. I drilled the boss through on the Explorer TB and siliconed the tube in place.
In the second pic, it shows how the Mustang throttle bracket was welded onto the Explorer linkage to set the cable hookup in the correct clock position.
I also have the harness / plug for the Explorer TPS so I'll be splicing that into the Mustang wiring.
I decided to modify the Mustang TPS instead of using the Explorer TPS. This way I dont have to cut into the Mustang wiring harness. To get the Mustang TPS to work, I cut the blade on the Explorer TB and elongated the holes on the Mustang TPS. It fits perfectly now.
Heads on, exhaust bolted up, valve train on and preload adjusted (shims) to 1/2-3/4 turns till tq spec, engine accessories on.
You all must think I move like a snail. However, I've been so busy with other things I haven't had time to work on the car.
I'm really looking forward to firing this thing up. Thanks to everyone for tips and suggestions along the way.
